HELP! Stock tach/temp/gas tank guages and instrument lights Not working...
after driving it real hard through our canyon run this morning...I checked all fuses...none were blown...any ideas? Radio and dome light do work though...
Any ideas before I start blindly hunting down the problem?
Thanks
Thanks
thanks, do you have an idea of exactly where a relay would be located for the instrumentation?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 »</TD></TR><TR><TD CLASS="quote">that little dimmer switch, proably went bad.. i had the exact same problem when i bought my 88</TD></TR></TABLE>
you mean that dial that makes the cluster lights dim and bright...that made your tach / temp and fuel guages go bad too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16A6Turbo »</TD></TR><TR><TD CLASS="quote">
you mean that dial that makes the cluster lights dim and bright...that made your tach / temp and fuel guages go bad too?</TD></TR></TABLE>.
my friend's dimmer switch went bad, and just the lights wouldnt work. the gauges still functioned properly.
slammedef06
Audio / Security / Video
Jan 31, 2005 09:01 AM
