Whats the difference between corrected and uncorrected hp at a dyno?
Old Oct 25, 2001 | 06:16 AM
Dr Pooface's Avatar
Default Whats the difference between corrected and uncorrected hp at a dyno?
Anyone?
Old Oct 25, 2001 | 06:32 AM
BoM's Avatar
BoM
Default Re: Whats the difference between corrected and uncorrected hp at a dyno? (Dr Pooface)
uncorrected is the dyno numbers u read right then and now.
but correccted is a converted number from standard variables like
temperature, humidity and stuff like that....
you standardize 1/4 mile times for the standard temperature and humidity and track
conditions too... like in NJ etown would be really cold in the fall
and CALI wouldn't be nor Texas
Old Oct 25, 2001 | 06:47 AM
eg6ajk's Avatar
Default Re: Whats the difference between corrected and uncorrected hp at a dyno? (bommiE)
other variables include atmospheric pressure, which varies with height
also on cold days the uncorrected numbers usually tend to be higher then corrected, and on hot days (80+ F) its the corrected # that are higher......
bascially you want one standard to compare the power your car makes, therefore you adjust variables accordingly...
dwilson
Feb 23, 2004 02:14 PM
Bbasso
Apr 10, 2003 06:17 PM
slimbo
Aug 8, 2002 03:51 PM
Project X
Jun 20, 2002 01:46 PM
JDM_DOHC_SiR
Apr 8, 2002 07:40 PM
