***CLICK FROM LEFT SIDE DASH AREA, CAR CUTS OUT?***
its a 90crx with a b16a1
WHEN I LET OFF THE GAS OR GOTO TAKE OFF EASY OR WHEN JUST DRIVING
AT A STEADY SPEED, I HEAR A CLICK LIKE THE MAIN RELAY AND
THEN MY CAR CUTS OUT FOR LIKE 1/2 SECOND, i replaced
the main relay, fuel pump , fuel filter, plugs , wires, igntion coil, cap,
i check my grounds(only have 4), no codes, im really getting
stumped and dissapointed! please help
thanks all
thanks all
Check the fuel pump ground wire from the computer to the main relay , If the wire has good continuity when you shake it check your computer , it might be going bad . The relay switches off (clicks) when it loses ground , then shuts off your fuel pump.
EFParkwayRacer
90 Civic Hatch
EFParkwayRacer
90 Civic Hatch
it could be your ignition switch on your steering column. when those go bad, the solders become melted and the car will shut off for no reason, and when the connection cools down you can start the car again, till it heats up and shuts off the car.
but it also sounds like a ground.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson »</TD></TR><TR><TD CLASS="quote">it could be your ignition switch on your steering column. when those go bad, the solders become melted and the car will shut off for no reason, and when the connection cools down you can start the car again, till it heats up and shuts off the car.
but it also sounds like a ground.</TD></TR></TABLE>
I had this problem to, cut off at a light i had to hold the key to get off the road.
andocommando
Sep 4, 2010 05:14 AM
3M TA3
Sep 2, 2006 09:22 PM
