Coilovers or Shock/Spring
Old Apr 3, 2004 | 10:47 AM
Hoppa's Avatar
Default Coilovers or Shock/Spring
Yah i was just wondering if i would be better off gettin the tein basic damper kit for $670 or b better off buying sum Koni yellows with sum springs, any input is appreciated.
Old Apr 3, 2004 | 10:50 AM
Kendall's Avatar
Koni Yellows with Ground Controls will outperform Tein Basic's anyday.
Old Apr 3, 2004 | 12:04 PM
LAKER HATER's Avatar
Default Re: (Kendall)
not worth spending $600+ for some teins. if you get a good set of coilovers and shocks, it will run you around the same price as teins. i would rather get ground controls and some tokico shocks.
Old Apr 3, 2004 | 12:56 PM
DIY's Avatar
DIY
Default Re: (lsturbo707)
id get neither.. go with the tein SS.. much better setup with adjustable dampening.
Old Apr 3, 2004 | 01:04 PM
Kendall's Avatar
Default Re: (DIY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIY &raquo;</TD></TR><TR><TD CLASS="quote">id get neither.. go with the tein SS.. much better setup with adjustable dampening.</TD></TR></TABLE>
The Tein SS isn't a track setup. It's really just a bling setup. Even the Tein Flex isn't really track worthy against a proper Ground Control/Koni setup. To get Tein's that will effectively compete with the GC/Koni setup, you'll easily spend a couple of thousand dollars.
Old Apr 3, 2004 | 02:19 PM
giff74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">The Tein SS isn't a track setup. It's really just a bling setup. Even the Tein Flex isn't really track worthy against a proper Ground Control/Koni setup. To get Tein's that will effectively compete with the GC/Koni setup, you'll easily spend a couple of thousand dollars. </TD></TR></TABLE>
Amen to that!! I am wanting tune my suspension in a little more and all everyone is saying is go with the Tein's, but the Ground Control with some good dampers, give a world of possibilities. Not to mention they are very cost effective.
Old Apr 3, 2004 | 02:34 PM
jDMJeRk's Avatar
Default Re: (giff74)
Tein SS is the way to go; No bling factor there. Lifetime warranty; fully adjustable; for them.
Old Apr 3, 2004 | 06:03 PM
lkshs123's Avatar
Default Re: (jdmjerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk &raquo;</TD></TR><TR><TD CLASS="quote">Tein SS is the way to go; No bling factor there. Lifetime warranty; fully adjustable; for them.</TD></TR></TABLE>
Well jdmjerk, judging by your name I can guess that you are a bandwagoneer, and have jumped on the JDM one. Tein is BLING suspension, unless you get the high end models and then its not worth getting them over some other stuff. I have been reading GC/Koni vs Tein setup for a while. From what I have read Tein SS is a much more bling factor and they are not as good as the GC/Koni set up.
litbulb
May 19, 2012 12:23 AM
CastCust
Jan 25, 2008 07:53 AM
IntegraGSR321
May 2, 2005 08:45 PM
SynTeg
Jan 30, 2004 04:21 AM
EBPSI
Sep 22, 2002 12:34 AM
