popping sound from intake
Old Apr 3, 2004 | 09:37 AM
powerbrad5000's Avatar
Default popping sound from intake
Hi I have a 94 vtec prelude with an aem cold air intake that has recently started making a popping noise. It usually does it after the engine revs to about 4000 and I have let off of it to shift. It is especially noticeable when it is under load like it is going uphill. Please help it is making me really nervous. I also have a greddy header and exhaust and I am running 93 octane fuel in it. Thanks.
Old Apr 3, 2004 | 12:22 PM
killa_lude's Avatar
Default Re: popping sound from intake (powerbrad5000)
you sure its the intake?
Old Apr 3, 2004 | 12:45 PM
Default Re: popping sound from intake (killa_lude)
Yeah I can tell that is where it is coming from and it kind of has that hollow sound from the intake tube. Maybe it has gotten out of time?
Old Apr 3, 2004 | 12:51 PM
VTECRaZeR's Avatar
hmm check the Filter itself. If it's the filter that does it, it's normal....it's just sucking air and it's the normal noise it makes..
Old Apr 3, 2004 | 02:25 PM
Default Re: popping sound from intake (VTECRaZeR)
Well it just started doing it so I dont think it is the filter or something normal, it almost seems like it is backfiring through the throttle body. Thats what made me wonder if maybe it is the timing but it doesnt run like it is out of time... I dont know but it is freaking me out. Thanks for the help.
Old Apr 3, 2004 | 03:41 PM
Cottonwoodz's Avatar
Sounds to me, like a lean backfire..
Old Apr 3, 2004 | 09:18 PM
Default Re: (Cottonwoodz)
So what does that mean a lean backfire is it going to blow up?
Old Jul 20, 2004 | 06:02 AM
darchon's Avatar
Default Re: (powerbrad5000)
bump, cause I got the same problem.
Old Jul 20, 2004 | 06:05 AM
93H22ACX's Avatar
Default Re: (darchon)
when mine did that it was the filter
Old Jul 20, 2004 | 08:21 AM
Matgallis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerbrad5000 &raquo;</TD></TR><TR><TD CLASS="quote">So what does that mean a lean backfire is it going to blow up?</TD></TR></TABLE> i dunno about backfire, i was thinking pre detention. Isn't backfire when the cylinder itself doesn't fire but as it's traveling out the exhaust part of the car it fires then?
Old Jul 20, 2004 | 08:43 AM
Speedra500's Avatar
Default Re: (Matgallis)
Have you done a compression check lately? It sounds to be like you are losing compression into your intake, either timing and just your valves are adjusted to tight
Old Jul 20, 2004 | 09:14 AM
preludeez's Avatar
Default Re: (Speedra500)
this was posted over 3 months ago...hope his engine didnt already go...
Old Jul 20, 2004 | 09:16 AM
Matgallis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeez &raquo;</TD></TR><TR><TD CLASS="quote">this was posted over 3 months ago...hope his engine didnt already go... </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darchon &raquo;</TD></TR><TR><TD CLASS="quote">bump, cause I got the same problem.</TD></TR></TABLE>that bastard! j/k
Old Jul 20, 2004 | 09:21 AM
Saki's Avatar
sorry to jack the thread... cai makes a clicking noise after i shut the enging off so i dunno...
honda305
28
Nov 10, 2009 01:19 PM
sohctodohc
Aug 19, 2009 05:02 AM
Lucman
Jun 25, 2009 09:56 AM
Sean DM
Honda Civic (2001 - 2005)
Oct 10, 2006 07:30 AM
slowww b18b1
Apr 3, 2004 09:40 PM
