tranny prob.
Old Apr 3, 2004 | 09:09 AM
Ditdogs's Avatar
Default tranny prob.
okie i just started to have this tranny problem, i was down at the track and after ripping it down the track 2 times my tranny started to stick in gear. the only way i could get it out was turnning the car off. i drove it home, the next day when i went to start the car i couldnt get it into any gear, i had to turn the car on and off untill it let me put it into gear. also i hear this zzzzzzzmmmmmmmm sound sometimes when i step on the clutch. could it be the syncros?
i have a 94 gsr tranny
Old Apr 3, 2004 | 09:56 AM
Chiovnidca's Avatar
Default Re: tranny prob. (Ditdogs)
Sounds like your clutch is dragging. Probably something broken or warped.
Old Apr 3, 2004 | 10:05 AM
Ditdogs's Avatar
Default Re: tranny prob. (Chiovnidca)
i have a exedy stage 2 clutch. think the clutch is bad? and not the tranny?
Old Apr 3, 2004 | 10:35 AM
swpdb16's Avatar
I had the same problem before, turned out to be low fluid in the clutch reservoir and the clutch line had to be bleed was perfect after that, But my clutch took a **** on me soon after that.
Old Apr 3, 2004 | 02:10 PM
Ditdogs's Avatar
Default Re: tranny prob. (swpdb16)
i just changed my gear oil and refilled all my fluids.
Old Apr 3, 2004 | 02:36 PM
Ditdogs's Avatar
would the throwout bearing case the clutch to not let me put it in gear sometimes? i know alot of the times the throwout bearing runs out of gresse and makes this zzzzmmmmmmmm sound, but i havnt heard it would couse me not to be able to put it into gear... hrmmm
Old Apr 3, 2004 | 04:34 PM
Ditdogs's Avatar
Old Apr 3, 2004 | 06:57 PM
Ditdogs's Avatar
la~
Old Apr 4, 2004 | 06:39 PM
Ditdogs's Avatar
Old Apr 4, 2004 | 07:44 PM
hondatim's Avatar
If it's hanging in gear, most likely has clutch disc spring that has fallen out and lodged between friction disc and pressure plate. That or friction disc has come apart. This does happen, even with supposedly 'better' aftermarket performance clutches.
globy123
Jun 20, 2008 10:54 AM
futurefastguy
Oct 13, 2006 10:32 AM
tony88crx
Jun 21, 2005 06:37 PM
reeder321
12
Dec 31, 2003 07:29 AM
phatintegra
Mar 21, 2002 08:46 AM
