1991 Rear Window
Old Apr 3, 2004 | 08:59 AM
hondanovice's Avatar
Default 1991 Rear Window
The rear window of my 1991 Accord LX stops about an 1/8 of an inch shy of fully seating into the top seal when closing. It has electric windows. I had this problem before and chose to force the window up (2 people) and LEAVE it up. A mishap forced me to have the regulator replaced. It still stops short and indications from the switch, it is because it is at it's limit. Is there any adjustment that can be made to give the window a little more upward motion? Is there some type of limit switch that I am overlooking?
Old Apr 3, 2004 | 03:13 PM
.bagged's Avatar
Default Re: 1991 Rear Window (hondanovice)
Take the door panel off and operate the window with out the panel on and watch to make sure the motor arm isnt getting caught or stuck and where
Old Apr 3, 2004 | 09:52 PM
kittedaccord's Avatar
also llook to see if its slippin off the track!!
Old Apr 4, 2004 | 11:53 AM
Riceburner247's Avatar
Default Re: 1991 Rear Window (kittedaccord)
3 things to look for:
1. Make sure where the window actuator is bolted, it is bolted to the correct position and the bolts are not loose.
2. Look for clearance with the motor arm by going through the up/down process and the door panel off.
3. See if there is an issue with the weather stripping on the window. Make sure it is seated correctly and that it isn't binding with the window.
Old Apr 4, 2004 | 11:56 AM
The_Todd's Avatar
Farts in the shower
Default Re: 1991 Rear Window (riceburner247)
And while you have the cover off spray in some silicone lubricant in the tracks and this will also ease window operation (repeat other windows as needed).
Old Apr 4, 2004 | 09:14 PM
Dr.PIMPer's Avatar
You Need a new window regulator/motor. I Have a 1991 Accord EX and I had the same problems with my rear windows. I had to replace both of the regulators but now they close.
Juliano Rivera
Jun 11, 2019 10:55 AM
rdone
Jan 17, 2015 02:39 PM
lastronaut
Oct 24, 2011 03:06 AM
VSG
Mar 7, 2008 10:46 AM
Mycroft Holmes
Mar 14, 2002 07:42 PM
