Suggestions on Precision turbo sizing - My SC61 is too big. SC34?
Old Apr 3, 2004 | 08:35 AM
Mad Cow's Avatar
Default Suggestions on Precision turbo sizing - My SC61 is too big. SC34?
I'm *NEVER* going to use the power that my SC61 is capable of making, and the lag is basically.... horrible. I'm looking for something with a lot less lag, but it needs to be capable of pulling all the way to red line on my B18C and be capable of at least 300whp (which they all seem to be). I'm looking at the SC34, but I can't really find any info on anyone with a B series running the 34. Will the SC50 provide the power and quick spool that I need?
Personal experiences/numbers with precision turbo/b18c's would be nice... don't forget to include you lag time.
Old Apr 3, 2004 | 08:48 AM
Sohc Driver's Avatar
Default Re: Suggestions on Precision turbo sizing - My SC61 is too big. SC34? (MadCow)
what are the specs of the sc34, sc50, and sc61 anyways?
Khoi
Old Apr 3, 2004 | 10:12 AM
illi Adik's Avatar
Default Re: Suggestions on Precision turbo sizing - My SC61 is too big. SC34? (Sohc Driver)
What is your exhaust set up? Im really surprised to hear the lag is that bad.
Edit: E Housing?
Old Apr 3, 2004 | 10:21 AM
TheShodan's Avatar
Moderator
Basically you need to calculate what your preferences are in terms of the goals that you want to have. Personally, it seems that many people like the SC44 w/ a slight change in turbine wheel to allow for faster spool up, but still be able to hold up to redline. These are good to about 330whp from my experience and specifications. You are correct though, the SC61 AS IS, would probably be a bit laggy for your needs if you stay stock. Now if you plan to build the motor, etc, then the SC61 could still do something for you. PM me, let's get you spec'd out.
Old Apr 3, 2004 | 10:36 AM
Mad Cow's Avatar
Default Re: (TheShodan)
E housing, .63a/r, 76trim... it doesn't hit 10psi till somewhere between 5500 and 6000. It's pretty bad... and I was way overzealous when I picked the SC61.
Old Apr 3, 2004 | 12:12 PM
*Boostwerks*'s Avatar
Wow...thats a pretty late spool for a SC61 with the .63 housing.
What are the specs on your motor/manifold/boost control?
Old Apr 3, 2004 | 12:19 PM
philipwight's Avatar
Default Re: (Bryson)
on my sc61 i build some boost before 32-3500 and hit full boost at about 47-5000.
Old Apr 3, 2004 | 12:28 PM
ndogg's Avatar
Default Re: (philipwight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philipwight &raquo;</TD></TR><TR><TD CLASS="quote">on my sc61 i build some boost before 32-3500 and hit full boost at about 47-5000.
me too. sounds like you have other problems madcow.
Old Apr 3, 2004 | 12:31 PM
Mr.DC2TurBo's Avatar
but is your trim 76?? 76 is pretty big compare to the usual 60 trim so that might be the reason for his lag.
Old Apr 3, 2004 | 12:34 PM
M.A.R.C.'s Avatar
Default Re: (Mr.DC2TurBo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">
but is your trim 76?? 76 is pretty big compare to the usual 60 trim so that might be the reason for his lag.</TD></TR></TABLE>
the 76 trim is refering to the exhaust wheel... if i remember right...
T350 76 trim = Stage 5 turbine wheel
T31 76 trim = Stage 3 turbine wheel
T31 69 trim = Stage 2 turbine wheel
or some ****.
Old Apr 3, 2004 | 12:45 PM
But the SC61 only comes in the stage 5 wheel.
Old Apr 3, 2004 | 01:05 PM
quikB18B's Avatar
Yeah although the sc61 is a pimp turbo it isn't for everyone. Alot people strive to hit #'s and sometimes they hit thier #'s but Id rather have a smaller turbo, capable of hitting the #'s I want while having a nice powerband
Ski Rebel 3 is running a Gsr hondata sc34 10-10.5 psi and hit just under 300.... 295/212. It was tuned by tony1. I am also running the sc34 on my Ls, and I like it, It's not very laggy and it pulls strong to redline.
Talk to Arturbo when considering something of this range Art usually recomends the sc50 over the sc34. Talk to him and he will point you in the right direction.
Old Apr 3, 2004 | 01:17 PM
Default Re: (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">Yeah although the sc61 is a pimp turbo it isn't for everyone. Alot people strive to hit #'s and sometimes they hit thier #'s but Id rather have a smaller turbo, capable of hitting the #'s I want while having a nice powerband
Talk to Arturbo when considering something of this range Art usually recomends the sc50 over the sc34. Talk to him and he will point you in the right direction. </TD></TR></TABLE>
50 Trim ownz.
Old Apr 3, 2004 | 02:04 PM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">But the SC61 only comes in the stage 5 wheel.</TD></TR></TABLE>
It comes with more turbine options but the stage 5 is what has worked best for me. Depending on the displacement I'll go with a larger 69 trim too.
art
Old Apr 3, 2004 | 02:11 PM
ndogg's Avatar
Default Re: (ndogg)
something is wrong with your setup dude. i just reviewed some logged data... i am hitting 10 psi at more like 4500. what manifold are you using? i'm running the inlinePro.
Old Apr 3, 2004 | 02:42 PM
JZ 97 SS 1500's Avatar
Default Re: (ndogg)
They are rated accordingly
SC50- 450hp
SC32- 480hp
SC34- 545hp
SC61- 680hp
All units PTE offers it in either a .48A/R or .63A/R
Jose
Old Apr 3, 2004 | 03:33 PM
nevin's Avatar
my wg would open up at 4800 on a tired ls motor, i think you are having other problems if you cant spool 10 pounds before 5.5-6
edit: and that was with S housing
Old Apr 3, 2004 | 03:41 PM
Trak_Day's Avatar
New User
he is running a Drag manifold and i think a 2.5" dp also, not real sure. tial wg and i am not so sure what size exhaust he is using
Old Apr 3, 2004 | 04:04 PM
jeremy.'s Avatar
bump.......
Old Apr 3, 2004 | 04:24 PM
DIRep972's Avatar
Smarter than you
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">something is wrong with your setup dude. i just reviewed some logged data... i am hitting 10 psi at more like 4500. what manifold are you using? i'm running the inlinePro.</TD></TR></TABLE>
i think hes right. 10psi @ 5500 is definitly abnormal. Is this a b16a?
Old Apr 3, 2004 | 04:29 PM
drvfast's Avatar
Imho you should go with the sc61. I have this turbo on a stock bottom end b16 and its not that laggy and i am running a 2.5dp, inline pro manifold. Hit full boost by 5400.
Old Apr 3, 2004 | 06:37 PM
DLB1994's Avatar
Default Re: (DroppedGSR)
the size of his exhaust on the car will play a big role in spool time, if its somthing like 2.25 thats why it has so much lag
Old Apr 3, 2004 | 06:49 PM
ndogg's Avatar
Default Re: (DLB1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">the size of his exhaust on the car will play a big role in spool time, if its somthing like 2.25 thats why it has so much lag</TD></TR></TABLE>
get a 3" dp and run that by itself. see if that helps your spool time. this is something you should have anyway.
Old Apr 3, 2004 | 07:03 PM
Default Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">
art</TD></TR></TABLE>
Really? I asked you before if they offered the 61 in a stage 3 wheel and I think you said no. Meh o wells.
Old Apr 3, 2004 | 07:50 PM
Arturbo's Avatar
Better than steak
25 Year Member
Its not offered in a stage 3 wheel from precison. The Stage 3 wheel is a T31 76 trim. The 69 trim I was talking about comes from the T04 family of turbines. So you can get the SC61 with either a T350 76 trim aka Stage 5 turbine, T04 .69 trim or T04 .76 trim aka the "p-trim".
And the SC61 is NOT offered in a .48AR either even tho their website says it does. Its a MISTAKE on their website that I pointed out to them.
art
