howdo i knwo if i need a new timing belt
Old Apr 3, 2004 | 05:43 AM
nbintegracing00's Avatar
Default howdo i knwo if i need a new timing belt
hi i have a 00grs with 78k on it i have the parts wich covers the timing belt off and i can grab the side of the timing belt and there is play in the belt i can move it back and forth a little is that bad?
Old Apr 3, 2004 | 05:59 AM
JDM PRO's Avatar
Default Re: howdo i knwo if i need a new timing belt (nbintegracing00)
i have the same play on my crx and it runs fine. I have a 99 Si and it's recomended to change it at 100k by the dealers manual so i assume you are pretty close to that interval w/ the b series motor
Old Apr 3, 2004 | 07:48 AM
RCautoworks's Avatar
Default Re: howdo i knwo if i need a new timing belt (JDM PRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO &raquo;</TD></TR><TR><TD CLASS="quote">i have the same play on my crx and it runs fine. I have a 99 Si and it's recomended to change it at 100k by the dealers manual so i assume you are pretty close to that interval w/ the b series motor</TD></TR></TABLE>
What manual is this ? The Honda manual recommends you change it every 60k. You could look at your timing belt and see what condtion it is in, but even if it looked fine I would still change it.
Old Apr 3, 2004 | 08:16 AM
mmuller's Avatar
Mad Scientist
Default Re: howdo i knwo if i need a new timing belt (90blackcrx)
yeah, when the timing belt gets old it stretches more and more
Old Apr 4, 2004 | 05:06 AM
Default Re: howdo i knwo if i need a new timing belt (mmuller)
bump anyone else have any sugestions pls
Old Apr 4, 2004 | 08:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nbintegracing00 &raquo;</TD></TR><TR><TD CLASS="quote">bump anyone else have any sugestions pls
What other sugestions would you like ? Change your timing belt.
5thGeneration
Nov 19, 2007 02:19 PM
jimjonez
Feb 28, 2007 02:59 PM
ZXRider
Dec 31, 2006 04:07 PM
OzWolfbane
Jan 7, 2005 05:14 PM
Si_LuDer
Apr 12, 2002 04:29 PM
