howling sound?!?!
Old Apr 2, 2004 | 08:23 PM
dcvt16's Avatar
Default timing belt area howling sound?!?!
anyone ever heard of a howling sound coming from the timing belt area? its loud enough to here from inside the car while driving. its a 1.5 1989 dx stock with a NOx problem. its not a belt slipping sound. it sounds like wind blowing when the window is barley cracked open... if you know what i mean. it doesnt really do it at idle but anything just passed it does. and it does it almost all the time.i just bought the car and trying to get smogged so i could put my other motor in but this **** is really buggin me and im not sure if its the water pump. any suggestions would be great thanx.
Modified by dcvt16 at 11:16 PM 4/2/2004
Old Apr 2, 2004 | 09:05 PM
Mohudsolo's Avatar
Default Re: howling sound?!?! (dcvt16)
I'd guess the bearing on the timing belt tensioner. If the belt is not old, you could change the tensioner without taking the belt off. If you take it off and it spins freely, then I would look at the water pump.
Old Apr 2, 2004 | 09:20 PM
96-EJ6 B18C's Avatar
Default Re: howling sound?!?! (Mohudsolo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohudsolo &raquo;</TD></TR><TR><TD CLASS="quote">I'd guess the bearing on the timing belt tensioner. If the belt is not old, you could change the tensioner without taking the belt off. If you take it off and it spins freely, then I would look at the water pump.</TD></TR></TABLE>
I agree but I would check the tension first...the timing belt may just be too tight, and that will cause a whining sound.
Old Apr 2, 2004 | 10:00 PM
dcvt16's Avatar
Default Re: howling sound?!?! (96-EJ6 B18C)
the timing belt is old...like i said i just bought the car and it just needs to pass smog then the motors outta there. im just afraid of it breaking before it acually gets to the smog shop. when i got it the timing belt was hella loose it made a kinds of noise..it was hitting the covers and flapping around so i adjusted it per spec then out of nowhere a few days later the sound started.
Old Apr 2, 2004 | 10:15 PM
dcvt16's Avatar
alright so now ive loosend the belt(a fair amount) and tightened to specs and just past that and the sound is the same no matter what the sound stays pretty damn loud.
Old Apr 2, 2004 | 10:17 PM
I'll have to side with Mohudsolo and say that either the tensioner is going bad, or the water pump is about to take a **** on you.
Old Apr 2, 2004 | 10:20 PM
dcvt16's Avatar
and i cant take yhe damn crank pully off yet. i blasted it w/ an impact gun for a gang of time and it wouldnt budge. damn buying other peoples problems!
Old Apr 2, 2004 | 10:38 PM
mmuller's Avatar
Mad Scientist
Default Re: timing belt area howling sound?!?! (dcvt16)
water pomp makes more of a high pitched noise, the sound you describe seems to be the timing belt being too tight
edit:nevermind
Old Apr 2, 2004 | 10:42 PM
dcvt16's Avatar
Default Re: timing belt area howling sound?!?! (mmuller)
well its kinda high pitched... i dont to spend the time and money on this worthless motor... damn this is pissing me off
ttt
Old Apr 2, 2004 | 11:02 PM
AllMTRWH0R3's Avatar
maybe the alternator belt is on to tight! mine makes the howl sound but I got rid of it and it didnt bother me too much!
goodluck hope ya pass smog!
Old Apr 2, 2004 | 11:03 PM
dcvt16's Avatar
Default Re: timing belt area howling sound?!?! (allmtrwhore2)
thanks but i did remove the alt belt and that wasn't it.
Old Apr 2, 2004 | 11:47 PM
dcvt16's Avatar
bump
Old Apr 3, 2004 | 12:50 PM
dcvt16's Avatar
bump
Old Apr 3, 2004 | 03:12 PM
dcvt16's Avatar
ttt.
Old Apr 3, 2004 | 03:35 PM
dcvt16's Avatar
ttt.
Old Apr 4, 2004 | 12:29 AM
dcvt16's Avatar
anyone else??
ttt
preludesilver
Feb 13, 2019 05:21 AM
clys
Feb 7, 2011 08:32 PM
SleeperGSR
May 29, 2008 03:27 PM
B18C1NMotion
Nov 20, 2007 11:27 AM
