Vtec studders around 40 + mph?
Old Apr 2, 2004 | 05:44 PM
Bay_707's Avatar
Default Vtec studders around 40 + mph?
when im going like 40ish vtec seems to kick in then go away and studder
this happened after i got new spark plugs and timing belt
and ideas? vtec hits fine in the lower gears. I have my ABS unplugged but other than that i cant think of anything wrong with my car. Oh its a b16 tranny with a 3 puck clutch
Old Apr 2, 2004 | 05:45 PM
lke2drvgsr's Avatar
Default Re: Vtec studders around 40 + mph? (707_Eclipse)
did you check your oil? go do that right now. vtec is regulated by oil pressure (right?) it'll engage and disengage a lot if you're low/empty on oil.
Old Apr 2, 2004 | 05:47 PM
Bay_707's Avatar
Default Re: Vtec studders around 40 + mph? (lke2drvgsr)
hhmmmmmm ill check now
Old Apr 2, 2004 | 05:53 PM
Bay_707's Avatar
oil is full, it has no problem in low gears like i said before only in high
Old Apr 2, 2004 | 05:55 PM
lke2drvgsr's Avatar
Default Re: (707_Eclipse)
you said it does it around 40 mphish, that's only in 1st and very low 2nd gear... i sure hope vtec isn't engaging in higher gears at 40 mph..
Old Apr 2, 2004 | 05:58 PM
Bay_707's Avatar
ive only had my car for like a week and a half im unfamiliar with vtec.. so its not supposed to kick in at higher speeds im assuming... but still it feels like its being limited at high mphs like something is studdering
Old Apr 2, 2004 | 06:00 PM
lke2drvgsr's Avatar
vtec on a stock gsr should engage at 5400 (i know i'm wrong, i always am on this, sorry guys, someone correct em ) and only when you're on wide open throttle or close to... so if you're cruising at 40 mph in 5th gear at 2300 rpm or whatever the hell it's at, your vtec sure as hell shouldn't be engaging
Old Apr 2, 2004 | 06:01 PM
Bay_707's Avatar
Default Re: (lke2drvgsr)
im talking about 3rd gear at 6,000 rpms
Old Apr 2, 2004 | 06:03 PM
lke2drvgsr's Avatar
3rd gear 6k rpms you should be around 60 mph... but vtec will only be engaged if the gas is all the way down (or mostly down)
Old Apr 2, 2004 | 06:04 PM
Bay_707's Avatar
no 3rd gear 6k rpm i am around 45 ish, i have a si tranny not a gsr
Old Apr 2, 2004 | 06:11 PM
GSRMON's Avatar
VTEC is a change in the cam lobe that is used to open and close the valves once it engages (not sure of RPM stock...but I have mine set to 4700RPM,) it doesn't disengage until its lower than the engage point I believe its 200 RPM less than the engaement point. Oil pressure is a know issue withe VTEC engagement but you already checked that, and CEL codes?
Anyhoo... I think u might want to check the plugs make sure they are torqued down correctly, also check the wires make sure nothing there is loose.
Old Apr 2, 2004 | 06:20 PM
Bay_707's Avatar
Default Re: (GSRMON)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRMON &raquo;</TD></TR><TR><TD CLASS="quote">VTEC is a change in the cam lobe that is used to open and close the valves once it engages (not sure of RPM stock...but I have mine set to 4700RPM,) it doesn't disengage until its lower than the engage point I believe its 200 RPM less than the engaement point. Oil pressure is a know issue withe VTEC engagement but you already checked that, and CEL codes?
Anyhoo... I think u might want to check the plugs make sure they are torqued down correctly, also check the wires make sure nothing there is loose. </TD></TR></TABLE>
No CEL codes.... it has no problem at all in lower gears kicking in so i dont know... its like vtec wants to kick in and it does then u go higher rpms and it goes away
Old Apr 2, 2004 | 06:42 PM
Kendall's Avatar
I would check to make sure the VTEC solenoid is properly functioning. It could be that it needs cleaning. Also, get ahold of an oil pressure gauge and check your oil pressure, this could explain part of your problem.
Old Apr 2, 2004 | 08:11 PM
Bay_707's Avatar
update... i notice i have low oil pressure.... but i have enough oil... its like the oil isnt heating up or something
Old Apr 2, 2004 | 11:56 PM
Bay_707's Avatar
bump
Old Apr 3, 2004 | 01:16 AM
drftwerk's Avatar
that'll do it.. VTEC engages when the engine temperature is right, when the oil is full and when there is proper oil pressure. If you have low pressure, it won't engage properly.
JSpekBB4
Oct 30, 2007 10:23 PM
NSX Bob
Apr 13, 2002 04:10 PM
Teal95Coupe
Nov 25, 2001 06:29 PM
ITR 0206
Aug 22, 2001 12:18 PM
itr501
Jun 25, 2001 10:06 PM
