ROLL THE FENDERS
Old Apr 2, 2004 | 04:17 PM
sohc00's Avatar
Default ROLL THE FENDERS
I low my car and she look like this / \ so i hook her up with camber kit after i properly adjusted, i started running in to problem with my tires rubbing the inside of the fenders. i just wonder is anybody here have experince with roll the fenders with the bat ? and how it work after u done it. is it recomend to do it or don't even try it it will mess up you fenders and a paint ?
Old Apr 2, 2004 | 07:22 PM
Sliced Beard's Avatar
Default Re: ROLL THE FENDERS (sohc00)
i rolled mine with a big hammer
all you do is stick the small end inbetween the tire and fender and slowly roll/wiggle it around until you get a smooth even bend throught the inside lip of the fender
Old Apr 3, 2004 | 06:06 AM
JDM PRO's Avatar
i used a dremmel to cut some of it and painted the open metal(rear). The fronts I just left it alone where it would rub on the inner plastic liner. I wish honda fenders are made the same as the VWs
dgerej2
Nov 23, 2009 08:36 PM
albertlnguyen
Honda S2000
30
Jun 16, 2008 12:04 PM
sixfiveoh
Nov 3, 2006 09:58 AM
msinsky14
Apr 16, 2006 02:12 PM
cilvia
Nov 16, 2005 06:47 AM
