Compression test on your Turbo B18C1 motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 TYPE R #103 »</TD></TR><TR><TD CLASS="quote">Any one out there can tell me what your motors reads on the compression tester in PSI.?</TD></TR></TABLE>
what are your numbers?
mine is 200 psi all the way across, im just wondering if that is to high for a boosted motor, im running with a B18C1 bottom end, wiseco flat top pistons that should be about 9.5:1, with a B18C1 head but im running with a B16 head, i would have thought it would have been lower then 200 psi. BTW this motor in my 94 GS-R, not my Type R
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamCracka »</TD></TR><TR><TD CLASS="quote">130 across in my boosted motor
that sucks dude sorry to hear that.
200 is good, especially with that compression ratio.
Landon
</TD></TR></TABLE>that sucks dude sorry to hear that.
Landon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BADGS-R »</TD></TR><TR><TD CLASS="quote">TeamCracka, what is your set up how did you arrive at 130 across?</TD></TR></TABLE>
I've got around a 9.2:1 CR, but I'm not sure exactly why every cylinder is at 130... I'm not too concerned since it still idles/runs fine and still pulls really hard at 8psi, but I'm planning on a rebuild in July so as long as it runs until then its all good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek00fbp »</TD></TR><TR><TD CLASS="quote">How many times do you crank the motor before you stop?</TD></TR></TABLE>
Disconect your ecu or whatever way you prefer. Crank the motor for 5 rotations @ wot.
turbochargeb18c
Sep 4, 2005 01:29 PM
advanracing62
May 27, 2003 05:51 PM
