what could cause a weak spark?
Old Apr 2, 2004 | 11:17 AM
wickedEFguy's Avatar
Default what could cause a weak spark?
Well first my car is a 90 Si and I have a JDM B16 I just swapped. Lately I've been getting code 15 and did some troubleshooting from the helms manual. Well I know my ECU is good and everythign flashes like it's supposed to.
The engine will crank and I my fuel pump primes like it's supposed to so I have no problems with my main relay.
Here's the weird part when I'm cranking over my engine it will try and start but it acting like there's a very weak spark. I'm starting to think either my coil or ignitor is going or has gone out.
Is there a for sure way to test the ignitor or coil itself with a voltmeter?
Old Apr 2, 2004 | 11:47 AM
spaceman's Avatar
Default Re: what could cause a weak spark? (wicked B16)
dis cap/rotor maybe?or timing is off maybe
Old Apr 2, 2004 | 11:58 AM
SleepyHF's Avatar
Default Re: what could cause a weak spark? (spaceman)
right your timing might be off by a tooth or so. Also check the compression do a leak down if you have too. I wouldn't check the dizzy or igniter at this point...like i said check compression aiiiiight
Old Apr 2, 2004 | 12:02 PM
Default Re: what could cause a weak spark? (SleepyHF)
timing is dead on so that's not a problem. The guy that I got my swap from drove the car with the B16 in his car to my house and we swapped over everything from there. Leak down test is great and I'm getting 195 all the way across
so as of right now it will crank but I'm getting any spark from it seems like. Is there a way to test the ignitor and coil?
Old Apr 2, 2004 | 01:08 PM
A+Foreign_Dave's Avatar
maybe new dist/rotor?
Old Apr 2, 2004 | 01:24 PM
Default Re: what could cause a weak spark? (A+Foreign_Dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A+Foreign_Dave &raquo;</TD></TR><TR><TD CLASS="quote">maybe new dist/rotor?</TD></TR></TABLE>
I'm trying to find someone's engine that I can try my dizzy first and see if the ignitor or coil went out on it
Old Apr 2, 2004 | 01:39 PM
SleepyHF's Avatar
thats a good way to do trail and error...good luck if you have anymore questions PM me or something
Old Apr 2, 2004 | 01:47 PM
thanx for all the help everyone
NWsleeperswaps
Nov 24, 2015 12:31 AM
jspecwhore
43
May 11, 2015 07:40 PM
jweeks
Jul 14, 2008 04:35 PM
Shurik_VT
Sep 12, 2007 08:02 AM
infinate bound
Mar 19, 2004 02:25 PM
