B20Z in my 89' cx/Need help!
Old Apr 2, 2004 | 08:30 AM
Wink1100's Avatar
Default B20Z in my 89' cx/Need help!
putting a B20Z in my 89' CX, here's what I got....
-2000 B20Z Engine
-91 Integra RS tranny (cable)
-91 Integra RS distributor
Have harnesses from both engines 91 Integra B18A and B20Z. Can I use these? Or should I just go with a 88-91 Civic SI Engine Harness? Also got the RS resistor box and 88-91 Civic SI resistor box. Which one do I use? Last but not least, Need an ECU. Which one can I use? Thanks for your help!
Old Apr 2, 2004 | 08:46 AM
bambam's Avatar
first off, what is an 89 cx? Do you mean a crx? or a dx or what?
Is ur car dpfi or mpfi?
If it's dpfi, ull have to swap to mpfi first.
The 90-91 teg and 88-91 si wiring are all identical. Just put in the motor, hook up ur si mpfi wiring to the motor. If ur using the 90-91 teg PR4, then you should use the same injectors. But, you can also use the PM6 if you wanted to and slap in the PM6 injectors into ur 90-91 teg manifold. But, if you can get ahold of 90-91 teg injectors and matching PR4 ecu, I would suggest to do so. Also, the injector resistor boxes may have a little different shape between them, but they're all the same. They are all using 6 OHM resistors. So, it doesn't matter which on u use. But, most people use the 88-91 si one because it looks better and most people compare the teg one to a twinky....lol.
Hope i helped.
Old Apr 4, 2004 | 08:33 AM
Wink1100's Avatar
Default Re: B20Z in my 89' cx/Need help! (Wink1100)
will the PR4 Integ ECU harness inputs in the computer fit my 89' civic CX harness? Or do I have to modify? can anyone help me out?
Old Apr 4, 2004 | 08:36 AM
phatrick2332's Avatar
There is no such car as a ******* 89 CX, tell us whether you have a dx, si, std, whatever..then maybe you will get some help.
pat
Old Apr 4, 2004 | 10:53 AM
Wink1100's Avatar
well anyhow u want it, telling u the model either a cx or dx, it's still dual point OEM wise. I wanna know if the OEM DX harness (cab harness) (U like that PAT?) works with the PR4 ecu?
Old Apr 4, 2004 | 12:21 PM
I Want An Si's Avatar
Default Re: (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">There is no such car as a ******* 89 CX, tell us whether you have a dx, si, std, whatever..then maybe you will get some help.
pat</TD></TR></TABLE>
HES GOT A FOCKING STD!!
There is a such thing as a CX, IN CANADA........
Old Apr 4, 2004 | 07:22 PM
Wink1100's Avatar
thamks! at least sumones aware.
Old Apr 4, 2004 | 10:07 PM
Sorry it was AM lol..
Just use the Si engine harness and graft it onto your DPFI harness, then use the integra ecu, which will plug right in to ur chassis harness since they are both obd0
Old Apr 5, 2004 | 06:19 AM
Wink1100's Avatar
thanks bud, I really appreciate the info.
Shawn
honcrx91si
Aug 10, 2006 11:50 AM
Fusion G2 Civic
11
Jan 13, 2006 05:32 AM
PureHonda06
Feb 24, 2005 07:58 AM
tdc
Feb 3, 2002 08:55 AM
JohnnyM
Jan 25, 2002 11:21 AM
