Throwout/release bearing has been but there is still a squeking noise.............
Old Apr 2, 2004 | 06:50 AM
mrmonk's Avatar
Default Throwout/release bearing has been replaced but there is still a squeking noise.............
OK, so I take my car to the dealership tp get my release bearing replaced because it has a squeaking noise coming from the engine bay and whenever I put my foot on the clutch the noise goes away. lol, and you guessed it the annoying *** noise is still there and only goes away when i put my foot on the clutch.
Any responses or comments/suggestions will be helpful. Thanks.
Old Apr 2, 2004 | 07:16 AM
JimBlake's Avatar
Default Re: Throwout/release bearing has been replaced but there is still a squeking noise............. (mrm
It was under warranty, right? Take it back & tell em they didn't fix it properly.
Old Apr 2, 2004 | 07:25 AM
mrmonk's Avatar
JIM YOUR THE GREATEST!
Old Apr 2, 2004 | 08:49 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It must be something inside the transmission then. When the car is running the transmission input shaft is always spinning while the clutch is engaged, even while in neutral. When you disengage the clutch the input shaft stops spinning (if the car is not moving) so it must be a problem inside somewhere.
Old Apr 2, 2004 | 10:12 AM
mrmonk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">It must be something inside the transmission then. When the car is running the transmission input shaft is always spinning while the clutch is engaged, even while in neutral. When you disengage the clutch the input shaft stops spinning (if the car is not moving) so it must be a problem inside somewhere. </TD></TR></TABLE>
I just spoke to somone at my work and he said it could be your alternater belt because your idle changes when you press the clutch in. I dunno :sigh: I got an appointment with the on monday morning... I guess we shall see what happens.
Old Apr 2, 2004 | 10:27 AM
JimBlake's Avatar
GEEZZZ..... Calm down for a minute...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk &raquo;</TD></TR><TR><TD CLASS="quote">I just spoke to somone at my work and he said it could be your alternater belt because your idle changes when you press the clutch in. I dunno :sigh: I got an appointment with the on monday morning... I guess we shall see what happens. </TD></TR></TABLE>WHAT?? The idle hardly changes at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Clutch throw-out bearing? Have someone push the clutch pedal while you stand in front listening. I imagine you'll be able to tell the location of the sound. Timing belt & clutch are on opposite ends of the engine.
ALWAYS, the best first thing for a noise is to pinpoint it's location.</TD></TR></TABLE>Well, did you ever do that?? Have some faith in your own ears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk &raquo;</TD></TR><TR><TD CLASS="quote">The squeaking noise STOPS when I put my foot on the clutch as soon as i let up off of it the squeaking starts again.</TD></TR></TABLE>That statement REALLY nails it as either the clutch or the tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Usually, a noisy T-O-bearing will get quiet just by resting your foot on the clutch pedal with a little pressure. Tranny bearings keep spinning until you disengage the clutch completely.</TD></TR></TABLE>Did you ever say which way this one goes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk &raquo;</TD></TR><TR><TD CLASS="quote">Screw it im taking it to dealership, it's under warranty lol.</TD></TR></TABLE>Just show them the noise. DON'T tell them which part to replace. That way they can't blame YOU for an incorrect diagnosis...
Old Apr 2, 2004 | 10:29 AM
gelok's Avatar
please keep us updated.... mine does squeak too after I changed my clutch.
Old Apr 2, 2004 | 10:42 AM
mrmonk's Avatar
This is what I plan to do.
I don't get this question...
Old Apr 2, 2004 | 10:47 AM
mrmonk's Avatar
If your refering to the noise and whether it goes away when i fully disengage or just press it lightly, your answer, is Lightly. Just by simply resting my foot on the clutch the noise goes away.
Old Apr 2, 2004 | 10:53 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk &raquo;</TD></TR><TR><TD CLASS="quote">I don't get this question... </TD></TR></TABLE>If you just show them the noise & tell em to fix it, it doesn't matter. But here goes (for other people with noisy clutches out of warranty...)
The question was whether it's your throw-out bearing or your tranny. Usually a loose rattling t-o bearing gets quiet right away if you simply press the pedal down just a bit, like you're taking up the slack in the pedal but not pressing it down.
If it keeps making noise until you press the pedal all the way down, then it's more likely a bearing in the tranny.
Another way is press the pedal all the way down suddenly & quickly. A loose t-o bearing gets quiet instantly. The tranny shaft takes a couple seconds to coast to a stop.
edit...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk &raquo;</TD></TR><TR><TD CLASS="quote">If your refering to the noise and whether it goes away when i fully disengage or just press it lightly, your answer, is Lightly. Just by simply resting my foot on the clutch the noise goes away. </TD></TR></TABLE>Yeah. That's exactly what I meant.
Old Apr 21, 2004 | 06:44 PM
mrmonk's Avatar
Not trying to resurect this thread or anything but I got the problem fixed yestorday and did not want to remake another thread.
I took my car back to the dealership for the third time and had the tranny opened up for the second time the technician replaced the throwout/ release bearing once again and thourghly lubed it up. He said that even though he had already replaced the T/O bearing it ran outta lube for some reason.
Cliff notes: For all you people out there with a loud or quiet squeaking noise when the engine is running and the clutch is engaged, get the T/O bearing replaced or Lubed up
Old Apr 21, 2004 | 07:13 PM
wreckedmyteg's Avatar
If you put the clutch in and it goes away, it's most likely a bearing in the tranny. Mine ended up being the main counter-shaft bearing.
Old Apr 21, 2004 | 07:23 PM
slooogsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckedmyteg &raquo;</TD></TR><TR><TD CLASS="quote">If you put the clutch in and it goes away, it's most likely a bearing in the tranny. Mine ended up being the main counter-shaft bearing.</TD></TR></TABLE>
aka - input shaft bearing?
mine needs to be replaced very soon........ how much did that run you?
Old Apr 21, 2004 | 07:28 PM
m R g S r's Avatar
I think he already mentioned that it was the throw out bearing, not the tranny.
Old Apr 21, 2004 | 07:38 PM
mrmonk's Avatar
The next step for me was to check out the main shaft in the tranny.
Old Apr 21, 2004 | 07:45 PM
Dan GSR's Avatar
yup, sound like you have a main shaft bearing problem
i've been thru this many times, its a common problem
Old Mar 25, 2007 | 04:31 PM
nokturnal_munkeeboy's Avatar
mr monk so what was the problem? was it inside the tranny or just the throw out bearing becuz i might have same problem and i dont want to spend alot of money for other things
qwertyintegra
Jun 12, 2019 11:48 AM
integra_101
Oct 16, 2013 01:29 PM
shermanyang
Dec 1, 2012 11:24 AM
HondaMan_TypeR
14
Jan 6, 2009 05:21 PM
