h22 swap is done just need some guick help
hey guys i just picked up a new ride that my friend bought... it's a 95 accord 4dr with an h22 swap... this thing is freakin' sweet... so anyways the axel needs to be replaced bad and the side markers dont blink... i read somewhere on one forum that someone corrected the side blinker problems but i cant remember where it came from... anyways if anyone knows a link or is selling a +250 hp axel for this gen accord with this swap i'd greatly appreciate it and if anyone knows how i can fix this damn blinker problem for my friend it would help too... i'm guessing it's just a wire but i need to know where it goes. thanks guys
Never take advice from a drunk...
Especially a drunk that lubricates my air tools with superglue by mistake cause it *looks* like a bottle of oil
The blinker wire is most likely loose, and wrapped around the axle, causing it to go bad. Replace the axle with a custom axle rated up to 400 hp and the blinker problem should be resolved.
wait how is the axel wrapping around the blinker wire... i'm thinkin' the blinker wire is an internal problem because all the blinkers dont work not just the front ones like even in the car when you signal nothing works...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2muchPSI »</TD></TR><TR><TD CLASS="quote">The blinker wire is most likely loose, and wrapped around the axle, causing it to go bad. Replace the axle with a custom axle rated up to 400 hp and the blinker problem should be resolved.</TD></TR></TABLE>
do i detect a hint of sarcasm here?
djsire
Apr 7, 2006 09:39 AM
