fog light problem
my fog lights went out, last week i know they were working and i just noticed them tonight. the dealership put them in for me (free). i doubt the bulbs burnt out, how do i go about checking to see if the fuses aren't bad/out of place?
my car is a 02 accord btw.
not sure if its oem, all i know is that the dealership put them in. so if dealerships carry the oem brand then it guess its oem.
and how do i go about checking them?
Modified by slowguy at 10:44 PM 4/1/2004
the light is on only when you trun on the low beam right?(no parking light, no switch, not on when high beam on,right?)
they are most likely to be oem
both blub cant blew out the same time, check the fuse first
could be a loosely connected grounding point if the fuse is good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oh Crap »</TD></TR><TR><TD CLASS="quote">oh yeah the ground is between the foglights behind the bumper. and there's another connection on the driver's side near the ABS module that you should check.</TD></TR></TABLE>
wheres the other connection near the ABS module? sorry for being a noob. all the connections seem fine and the bulbs are good as well.
Well the install manual on mine said to install the connector under the intake accordian hose, but in the pic it showed the ABS module. There is a plug under the intake, but it doesn't fit.. but it does fit the one near the ABS. If everything seems okay, take it to the dealer..it should have some type of install/product warrenty.
What probably sucks is if a relay went bad (located near battery, and driver kick panel.. kinda small and un-noticable though)
TheTurtle
10
Nov 10, 2006 02:27 AM
KtHaNxBai
May 25, 2006 10:37 AM
