Electrical problem? 1 Turn Signal Is Faster Than The Other! Please help!
Old Apr 1, 2004 | 08:06 PM
r0c5t4r's Avatar
Default Electrical problem? 1 Turn Signal Is Faster Than The Other! Please help!
^^ I installed a CAI today and for some reason when I put the bumper and everything back together one of the turn signals stopped working. I checked all the wiring and grouding points and fuses, nothing seems to be wrong with any of them. When I started playing with the bulb and smacked it a couple times it worked but now is blinking alot faster than the other turn signal. Has anybody else had this problem, if so hwo did you fix it? What else can I check or do to fix it?
Old Apr 1, 2004 | 08:29 PM
miketegra's Avatar
Default Re: Electrical problem? 1 Turn Signal Is Faster Than The Other! Please help! (dfunkd)
Check all other bulbs to see if one is blown. It messes with the relay when a bulb in the circuit is out.
If not that, then perhaps a wire was pulled out or was yanked/cut and is shorting out.
Let us know what you find out !
Old Apr 1, 2004 | 08:33 PM
r0c5t4r's Avatar
Nothings wrong with the bulbs because I plugged them into the normal side and they worked fine. I checked the wiring but nothings loose or cut, hmm. I have no idea, i'll check again tomorrow. Let me know what else coudl be wrong.
Azavala
Apr 8, 2016 02:14 PM
Uncle Ben's
Jul 8, 2007 12:08 PM
DynastyRacer22
Honda Civic (2001 - 2005)
May 20, 2007 08:39 PM
jdm_junkie
Aug 12, 2004 06:09 PM
InTeGrA B18b1
Jul 14, 2004 05:50 PM
