Upper control arm*help*
Old Apr 1, 2004 | 07:46 PM
Groove_D's Avatar
Default Upper control arm*help*
my upper control arm is rubbing against the inner fender wall... or its the part of the body... when you see the pic, you will know what i mean.
can i just shave off the marked piece?
will it effect the control arm in any way?
Old Apr 1, 2004 | 08:16 PM
RED_October94LS's Avatar
Default Re: Upper control arm*help* (Groove_D)
Looks really minor piece/area, I dont think it would affect the control arm in any way.
Old Apr 1, 2004 | 08:49 PM
Groove_D's Avatar
Default Re: Upper control arm*help* (Blckteg96)
are you sure?
should i paint it and coat it after?
Old Apr 1, 2004 | 11:06 PM
LowTEC SaiMike's Avatar
what kind of control arm is that ...... is it alright for ur car ?
Old Apr 1, 2004 | 11:56 PM
jDMJeRk's Avatar
Default Re: Upper control arm*help* (BomBoi)
When I put in my ingalls kit on my 91 teg (its just a camber kit not the control arm) I had to shave the stock arms off I believe on both sides; I think youll be fine. My stock ones are at least
hth
Old Apr 2, 2004 | 05:04 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I wouldn't mess with that, the metal is curved out like that to help increase stiffness and rigidity of the control arm.
Old Apr 2, 2004 | 06:42 AM
95 integra's Avatar
Default Re: Upper control arm*help* (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't mess with that, the metal is curved out like that to help increase stiffness and rigidity of the control arm.</TD></TR></TABLE>
Thats what im saying...it probably wont matter, but it wont be as strong.
Old Apr 2, 2004 | 06:53 AM
Groove_D's Avatar
Default Re: Upper control arm*help* (95 integra)
well yea.. but with ingalls its rubbing the inner walll...
so i dont even know whats better, leave it hitting the wall or shave it off.
Old Apr 2, 2004 | 08:51 AM
Community Builder
I personally can't picture where you're talking about that it's hitting. I don't remember that part of the arm being anywhere near any part of the sheetmetal shock tower or frame.
Old Apr 2, 2004 | 09:07 AM
631 Teggy's Avatar
This is EXACTLY right... The roll is the only thing keeping that controll arm from bending... If you do shave it, you may need to do some custom fab work to add some strength back to it...
Old Apr 2, 2004 | 09:21 AM
Community Builder
Default Re: Upper control arm*help* (631 Teggy)
Well, the fact that the stamped arm has a C-shape cross-section is what gives it most of it's rigidity, while the rolled edge just adds a little more strength. But yeah if you take away the edge there's a possibility that a crack might develop on the sides of the arm.
Old Apr 2, 2004 | 09:32 AM
jonsteR's Avatar
If that's rubbing, then obviously, there's something wrong. Fix that instead of shaving the UCA.
When the rubber on my ingalls kit was destroyed, the UCA was very close to rubbing on the same spot. I replaced it with an ingalls poly kit and the problem was solved. Also make sure the adjustment on your ingalls (per arm) is even.
Old Apr 2, 2004 | 10:10 AM
Groove_D's Avatar
Default Re: Upper control arm*help* (jonsteR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk &raquo;</TD></TR><TR><TD CLASS="quote">When I put in my ingalls kit on my 91 teg (its just a camber kit not the control arm) I had to shave the stock arms off I believe on both sides; I think youll be fine. My stock ones are at least
hth </TD></TR></TABLE>
well this guy did the same thing what i want to do.
and my ingalls are relatively new. 6 months old.
i heard some one else had the same problem as i do and they shaved the arm, but it was in a del sol.
the adjustment per arm is even as i did the allignment, so it cant be not even, unless the guy messed up.
but i just finished shaving it.
i will let you know how is it after i put it in.
this is what it looks like shaved
Old Apr 2, 2004 | 10:12 AM
roadrunner's Avatar
...just double checking -- are the control arms on their correct sides? They are mirrored, left and right, but not the same...
Old Apr 2, 2004 | 10:28 AM
Groove_D's Avatar
Default Re: (roadrunner)
yea man.
i never changed my passenger side control arm before.
so its still stock.
thats the pic of how it was rubbing.
on the right, can you guys see the marks?
Modified by Groove_D at 8:10 PM 4/2/2004
Old Apr 2, 2004 | 12:04 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadrunner &raquo;</TD></TR><TR><TD CLASS="quote">...just double checking -- are the control arms on their correct sides? They are mirrored, left and right, but not the same...</TD></TR></TABLE>
If he got one on the wrong side, the caster reading would be WAY WAY off and the spindle would be severly tilted backwards.
Old Apr 2, 2004 | 12:31 PM
G
sh!t happens.
Default Re: (PatrickGSR94)
let me know how it does cause mine does the same thing
Old Apr 2, 2004 | 02:07 PM
Jer'rome's Avatar
Default Re: (G"UNIT)
read this thread https://honda-tech.com/zerothread?id=785102 his is doing the same thing AND i noticed you too arnt using the stabilizing bar the goes behind the spring (gold piece)
Old Apr 2, 2004 | 11:31 PM
Groove_D's Avatar
Default Re: (low'N'slo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowNslo &raquo;</TD></TR><TR><TD CLASS="quote">read this thread https://honda-tech.com/zerothread?id=785102 his is doing the same thing AND i noticed you too arnt using the stabilizing bar the goes behind the spring (gold piece)</TD></TR></TABLE>
you not suppose to use it.
Old Apr 3, 2004 | 03:21 AM
Jer'rome's Avatar
Default Re: (Groove_D)
um why not? just last week i installed my ingalls camber kit and i fit just fine.
So let me get this straight. The parts that COME with the upper control arm your not gonna use so now You want to cut out piece of the arm?!?!!?!?!?
Old Apr 3, 2004 | 10:01 AM
Groove_D's Avatar
i already did cut it out.
the piece doesnt go on the top of the camber kit.
i have no idea how you fitted that on.....
does anyone else fit it?
Old Apr 3, 2004 | 10:41 PM
Groove_D's Avatar
i took it apart today again... and i made that thing to fit on the ingalls camber kit. so much big of the difference.
still left side reamains to be done.
Old Apr 4, 2004 | 06:21 AM
Jer'rome's Avatar
I told u! Thanks for listening
Old Apr 8, 2004 | 11:15 AM
blackludeH22's Avatar
Groove_D, I gotta question, I was wondering if you would have the original bolts that u had replaced with the ingal kit?
I have some cheap generic camber kit in my car and it broke twice ( I think I have something like anchor bolt) and for now I rather put the stock one back untill I gather some money for a different kit, would you still have urs by chance and maybe I could buy them from you??
Please let me know asap.
Thankyou much
Old Apr 9, 2004 | 11:21 PM
Groove_D's Avatar
Default Re: (blackludeH22)
i have the ones i bought for the passengers side.
they are aftermarket and brand new.
the drivers side i dont have them...
how much are you willing to pay?
97elitehonda
Suspension & Brakes
May 7, 2007 10:06 AM
markwitdada9
Jan 31, 2006 05:15 PM
CD7power
Jan 14, 2005 02:34 PM
allowmetointroducemyself
Dec 16, 2004 05:17 PM
