y8 manifold and injectors??????
i am using a d15 block z6 head y8 im and a b18 throttle bdy with new y8 injectors and wiring i have been told that the y8 injectors and wiring has caused some people some trouble when doing the mpfi swap so i am having problems with my swap but it dosent seem like its an injector prollem. im just not getting any fire and i am shooting a code 20 if there is anyone here who has any experience with this code 20 i would greatly appreciate the help thanks Jeremy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefaazztcrx »</TD></TR><TR><TD CLASS="quote">so how did you wire up your injectors</TD></TR></TABLE>
just get rid of the injector box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed6 »</TD></TR><TR><TD CLASS="quote">You also need the proper injector plugs.</TD></TR></TABLE>
I didnt feel the need to type the obvious.
i was told that it would burn your injectors up if you done that because the dx injector ran constantly and if you run the y8 injectors that way itll will burn them up but if this isnt the case someone tell me what wires go where to make this happen and ill do it to thanks Jeremy
im not a wiring fool so i cant figure this stuff out myself i would have it all messed up and i can barely do it when i got destructions
Xemu
Oct 2, 2007 10:21 AM
big-cat
Nov 3, 2006 07:17 PM
hondaless
Aug 31, 2002 07:22 PM
