OT: anyone using a generic digital A/F gauge like this?
Old Apr 1, 2004 | 05:36 PM
RTW DC2R's Avatar
Default OT: anyone using a generic digital A/F gauge like this?
Im looking for something simple like this, just a digital read out of the A/F ratio. Most of the displays out on the market come with wideband built in but I dont need that because I have the wideband already installed. Ive used other LED type gauges before but Id rather have a digital display. Anything I should be wary of if I wanted to run something like this off my wideband?
Thanks
Old Apr 1, 2004 | 05:43 PM
ZygSpeed's Avatar
Default Re: OT: anyone using a generic digital A/F gauge like this? (RTW DC2)
I don't see any "problem", but it looks like it's only a 3 digit display for the voltage.
What is the relationship between that "voltage" and the actual A/F ratio?
P.S. I just bought one of the AEM wideband units w/gauge.
Modified by zygspeed at 9:54 PM 4/1/2004
Old Apr 1, 2004 | 06:01 PM
RTW DC2R's Avatar
well theres all kinds of different gauges like the one I posted. you can get gauges that input the voltage and output the A/F.
Im running the AEM WB already, and they dont have just the gauge available and wont have it available until late this year. I wish they did b/c there guauge is set up really nice with LED and LCD readouts.
Old Apr 1, 2004 | 06:37 PM
ZygSpeed's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote"> I wish they did b/c there guauge is set up really nice with LED and LCD readouts. </TD></TR></TABLE>
I just opened my package from P1 (with the AEM wideband) and I did get and have the Black faced on black housing gauge.
Looks like they're just becoming available and Jack may still have a couple left (of his recent incoming order). HTH Ed
Old Apr 1, 2004 | 06:45 PM
RTW DC2R's Avatar
yeah but doesnt it already have the WB built in and its like $400? I just need the display, I dont need the WB. Ill hit up Jack and see what hes got to say.
Old Apr 1, 2004 | 07:24 PM
92TypeR's Avatar
FSAE
If that falls through we've been using the old school FJO display (not the new fancy LED one) and I think you can still pick those up separately.
Old Apr 2, 2004 | 03:13 PM
confidence's Avatar
Default Re: (92TypeR)
well there is always the Nordskog unit. they make nice stuff at reasonable prices too
http://www.nordskogperformance.net/m9200.html
the discription says it come in 2 5/8 size but it also comes in the 2 1/6 model #m9200 and the m9200 is cheaper. you can order it in amber to match you itr lighting
Old Apr 2, 2004 | 04:34 PM
RTW DC2R's Avatar
It looks like most(all) of these gauges only display the voltage readings. .500 = 14.7 a/f that would get kind of annoying. Im not sure if I can calibrate it with my EMS to output the a/f reading or not.
Old Apr 2, 2004 | 04:44 PM
ZygSpeed's Avatar
I remember when Yack simply used a voltmeter to do his tuning.
Old Apr 2, 2004 | 04:49 PM
RTW DC2R's Avatar
haha that must have driven him kinda nutty.
apparently the gauge/wb combination is a function of the stand alone thats used. So as long as you have a calibration table for the WB, if you tap into the O2 wire from the stand alone you should get an actual a/f reading off the WB instead of a voltage reading. but thats ONLY if you have a current WB set up that reads a/f and not voltage. :shrugs: there are some nice little gauges out there that are relatively cheap
Old Apr 2, 2004 | 04:55 PM
ZygSpeed's Avatar
You might be able to find some data for a Bosch wideband O2 on the web.
That would essentially be the "calibration table" you mentioned, and just compare the O2 voltages you get with the table to determine the A/F.
Hehe ... but it looks like you already know that.
Hows this for a quick Google search?
http://www.techedge.com.au/vehicle/wbo2/wbntk.htm
Good link on that page:
http://techedge.com.au/vehicle/wbo2/wblambda.htm
Old Apr 2, 2004 | 06:25 PM
92TypeR's Avatar
FSAE
Default Re: (zygspeed)
Displays AFR instead of voltage.
Old Apr 2, 2004 | 08:37 PM
RTW DC2R's Avatar
Ed, yeah I know about the TechEdge, but it comes with a WB, not just the gauge AFAIK.
92TypeR, do u know if that one needs to be calibrated so it reads a/f instead of voltage? or is it already set up to calibrate the a/f just by hooking it up to the O2 wire off the ECU?
Old Apr 2, 2004 | 11:40 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">92TypeR, do u know if that one needs to be calibrated so it reads a/f instead of voltage? or is it already set up to calibrate the a/f just by hooking it up to the O2 wire off the ECU?</TD></TR></TABLE>
I'm not 100% certain on that, I'll take a look this weekend and see if the plugs on the meter are equivilent to the 5wire. I know, at least on the cars I've played with that have that meter, it is plugged into the FJO controller box. But as I said, not 100% certain it can be used directly off of O2 voltage, but I'll do my best and see if it appears to work like that.
deeweezy187
Jan 15, 2008 06:45 PM
JACER63
Feb 27, 2007 07:51 PM
JMcDB18C
May 12, 2005 04:51 PM
FredoSP
Aug 24, 2004 05:25 AM
One8Hatch
Nov 30, 2001 05:10 PM
