Size of wheel spacer for JDM DC5R rims?
Old Apr 1, 2004 | 04:55 PM
BlueIntegraBoy's Avatar
Default Size of wheel spacer for JDM DC5R rims?
Does anybody know what size wheel spacer I need if I get JDM DC5R rims with 215/45/17 tires for my RSX Type-S? The offset on those are +60. Stock rims are +45 offset with 205/50/16 tires. I already searched, but I keep getting where to buy wheel spacers.
Old Apr 1, 2004 | 09:49 PM
RsxVengeance's Avatar
you can get by with a 5mm spacer.
Old Apr 2, 2004 | 01:02 AM
ep3minivan's Avatar
Default Re: (RsxVengeance)
if you want the +45mm offset again, then get 15mm spacers. but like rsxvengeance said, 5mm spacers will do.
Old Apr 2, 2004 | 08:49 AM
f1nal zeros's Avatar
I have the 5mm spacers on my jdms. It works fine. But you will also need to get exteneded wheel studs.
Old Apr 2, 2004 | 11:15 AM
Default Re: Size of wheel spacer for JDM DC5R rims? (BlueIntegraBoy)
Thanks guys, I heard that I don't need spacers for the front, just for the back.
Old Apr 2, 2004 | 02:51 PM
Yeah, you only need them for the rear. Front is ok.
Old Nov 29, 2004 | 07:17 PM
jdmvtec28's Avatar
Default Re: (f1nal zeros)
Are the extended wheels studs a must with the DC5R wheels and a 5mm spacer?
I ran into the same problem tonight... tried to install the wheels and found the backs don't have proper clearance.
Old Nov 29, 2004 | 08:13 PM
silver comet's Avatar
Default Re: (jdmvtec28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 &raquo;</TD></TR><TR><TD CLASS="quote">Are the extended wheels studs a must with the DC5R wheels and a 5mm spacer?
I ran into the same problem tonight... tried to install the wheels and found the backs don't have proper clearance.</TD></TR></TABLE>
Don't take my word for it, but I heard that you only need extended wheel studs if your car is lowered. Maybe someone else can clear that up.
Old Nov 29, 2004 | 08:57 PM
jdmvtec28's Avatar
Default Re: (silver comet)
The exteneded wheel stud is not conditional upon being a lowered car...
I am concerned that with a 5 mm wheel stud there is 5mm less thread being used by the lug nut.
Old Nov 29, 2004 | 09:05 PM
ep3minivan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 &raquo;</TD></TR><TR><TD CLASS="quote">The exteneded wheel stud is not conditional upon being a lowered car...
I am concerned that with a 5 mm wheel stud there is 5mm less thread being used by the lug nut.</TD></TR></TABLE>
with 5mm less, it shouldn't be too big of a concern. but, that would be the reason why you would need extended studs if you use a thicker spacer.
you don't have proper clearance because the wheel is tucked in too far. when i didn't have spacers, my wheels would bang against the control arm over big bumps with passengers in the back(lowered on tein s techs)
Old Nov 30, 2004 | 07:55 PM
jdmvtec28's Avatar
Default Re: (ep3minivan)
I purchased a set of 5 mm wheels spacers today, they are working fine... before purchasing them I did test fit an 8mm wheel spacer and that fit as well. I achieved 6 full turns or more with the 8mm wheels spacers. Safety first.
raytrix
Wheels
14
Sep 17, 2011 11:11 AM
mugenboard
Jan 13, 2010 08:51 AM
Dan-o da Man-o
Honda Civic (2006 - 2015)
11
May 6, 2007 07:56 AM
Zatzy
Feb 14, 2005 08:16 PM
2kstreetcivic
10
Jan 19, 2005 04:29 PM
