Skunk2 Stage 1 or 2 camshafts
Old Apr 1, 2004 | 04:53 PM
vtec_fox's Avatar
Default Skunk2 Stage 1 or 2 camshafts
hey, I have a 00 B18C1 and Im in the process of upgrading my valvetrain. Which setup is better for my vehicle. Stage 1 cams with upgraded valves, springs, and retainers. Or Stage 2 cams with upgraded valves, springs, retainers and ITR pistons for higher compression because the stage 2 cams cause compression leaks. So which do you guy thinks would be better for my GSR!!!
Old Apr 1, 2004 | 04:56 PM
mmuller's Avatar
Mad Scientist
Default Re: Skunk2 Stage 1 or 2 camshafts (vtec_fox)
mmmmmm....what do you think?
i think the answer is obvious....
Old Apr 1, 2004 | 05:27 PM
eyeamvic's Avatar
You're gonna need more compression than some ITR pistons to power those stage 2's depending whether you go with the USDM or JDM ITR pistons. Go with the JDM ones and go with a 2-layer headgasket to help out some. Don't forget you're gonna need tuning done in order to get the best power out of the cams and upgrading fuel setup would help also.
Old Apr 1, 2004 | 06:04 PM
Kendall's Avatar
Without bottom end work, I wouldn't venture past the stage 1's.
Old Apr 1, 2004 | 07:16 PM
vtec_fox's Avatar
Default Re: (Kendall)
installing the pistons is considered bottom end work. Obviously you don't have a full understanding of a motor yet son. and many others have agreed to going with the stage 2 setup anyways.
IggyBcool
16
May 14, 2005 05:57 PM
IggyBcool
May 14, 2005 01:56 PM
RedheadRacing
Dec 24, 2004 04:04 AM
Combustion Contraption
14
Aug 16, 2003 04:11 PM
10K2HVN
Jan 15, 2003 11:06 AM
