Suspension Question...Need some advice
Old Apr 1, 2004 | 04:19 PM
WuRKD b16's Avatar
Default Suspension Question...Need some advice
I have a 00 EJ8/Ex dropped with H&R Sport springs and tokico blues, spoon front upper strut bar, SRR sway kit. I'm not sure if its because im not used to the sway kit, but since i put it on it almost feels like my rear might step out. I was wondering if this is a good step up and its just in my head or i should get something else to neutralize the rear sway. Thanks a lot
Old Apr 2, 2004 | 12:12 PM
suspendedHatch's Avatar
Default Re: Suspension Question...Need some advice (WuRKD b16)
If it feels too loose try getting an upgraded front sway bar.
Old Apr 2, 2004 | 01:50 PM
rapid_roy's Avatar
Attend a driving school before you die.
In the meantime, lower your rear tire pressure 2-3psi, and don't let off the throttle on corner entry or mid corner.
Old Apr 2, 2004 | 02:11 PM
WuRKD b16's Avatar
Default Re: Suspension Question...Need some advice (rapid_roy)
yea i know not to let go of throttle im saying when pushin thru da turn it feels like it might give...so i should just get a thicker front or will that give me understeer?
Old Apr 2, 2004 | 02:58 PM
rapid_roy's Avatar
Yes, a thicker front bar will promote understeer. The problem becomes determining how thick is just right. Since I am not familiar with suspension tuning and fornt swaybars on Ex's, I'll stop talking now.
But play around with the tire pressures and that might alleviate the problem for now. +2 front, -3 rear.
Old Apr 3, 2004 | 02:21 PM
WuRKD b16's Avatar
thanks man.... anyone else know a good setup for the front bar?
Old Apr 3, 2004 | 09:30 PM
thegsrman's Avatar
i've been told that when you stiffen up your rear with a bigger swaybar like the way you did, your back will tend to want to step out so it might not be in your head. you might want to upgrade your front swaybar also, that might help. btw how big is your rear swaybar?
Old Apr 4, 2004 | 08:42 PM
WuRKD b16's Avatar
Default Re: Suspension Question...Need some advice (thegsrman)
its a srr sway bar 19mm
Old Apr 5, 2004 | 08:00 AM
WCI's Avatar
WCI
I have an si front sway on my EK and it feels good to me. I don't know if it is different that ex though.
Old Apr 5, 2004 | 08:39 AM
Default Re: Suspension Question...Need some advice (WCI)
Oversteer and understeer aren't all or nothing. You NEED a little understeer on corner entry. It's not always a bad thing. Especially if you're just getting started, I think your car should be neutral or tipped more towards understeer rather than being loose and drifting in all the corners. You need a little more stability so get a thicker front swaybar. Since your rear is only 19mm, I would shoot for about 22mm up front. I don't know what your current front bar diameter is. The GSR is 24, so maybe check what a LS front bar is.
Other thing you can do is reduce your front camber or add to the rear. I don't know what your setup is, but try an equal amount of camber front and back. That should help stabilize the car some.
Old Apr 5, 2004 | 01:58 PM
Katman's Avatar
if you pick up an Si coupe front swaybar, its 26mm...nice n' thick n' big... ...that didnt come out right
Old Apr 5, 2004 | 03:10 PM
APEX CRX's Avatar
Default Re: (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">its 26mm...nice n' thick n' big... ...that didnt come out right </TD></TR></TABLE>
ha ha
Old Apr 6, 2004 | 12:46 PM
WuRKD b16's Avatar
Default Re: Suspension Question...Need some advice (shaundrake)
thanks a lot peeps for da help....i think imma look for a si front sway bar or does anyone have one i could take off ur hands for cheap
Old Apr 6, 2004 | 06:11 PM
thegsrman's Avatar
well it seems that you have your answers. good luck. i know this is a dumb question but what does srr stand for? cuz i'm looking for a good 22mm sway bar (rear) for my gsr.
Old Apr 6, 2004 | 09:03 PM
WuRKD b16's Avatar
Super Road Racing
zippo1130
15
Jan 15, 2008 07:45 PM
jredhonn
Suspension & Brakes
Dec 26, 2007 05:34 PM
rexorz
Feb 23, 2003 03:23 PM
