Smoking alote and cant find right idle in my b18b1 ls
Old Apr 1, 2004 | 12:28 PM
kerby116's Avatar
Default Smoking alote and cant find right idle in my b18b1 ls
my ls is smoking alote. by alote i mean a whole lot. it will fill up my house if the windows are open. it also have trouble staying a a descent rev. it going up and down about 1.5 rpm at a time. i looked for a vacuum leak and found nothing. i just put the head on, and adjusted the valves. i really need my car back its been down for 2 weeks.
Old Apr 1, 2004 | 01:42 PM
Code Blue's Avatar
Default Re: Smoking alote and cant find right idle in my b18b1 ls (kerby116)
what color is the smoke
Old Apr 1, 2004 | 01:52 PM
kerby116's Avatar
Default Re: Smoking alote and cant find right idle in my b18b1 ls (Code Blue)
like a white, light grey color
Old Apr 1, 2004 | 05:29 PM
mmuller's Avatar
Mad Scientist
the smoke could be your headgasket.A leakdown test could pinpoint the problem.
does the smoke smell like gas or kinda sweet?
the idle could be your fitv check that
Old Apr 1, 2004 | 07:24 PM
kerby116's Avatar
Default Re: Smoking alote and cant find right idle in my b18b1 ls (mmuller)
yeah. I sure it is the head gasket because there is a little bit of oil in the coolant and the head gasket was not in the best shape when i put it on.
Old Apr 1, 2004 | 07:34 PM
thad
Guest
Posts: n/a
time to take the head off again. by now you should be able to do it in the dark with no hands. might want to throw up a WTB for an oem headgasket. find valves yet?
Old Apr 1, 2004 | 07:45 PM
kerby116's Avatar
Default Re: Smoking alote and cant find right idle in my b18b1 ls (thad)
no im going to wait on some after market valves. there 200.00 on ebay for the whole set. if anyone can find them cheaper let me know.
Old Apr 1, 2004 | 07:46 PM
kerby116's Avatar
o'yeah thad aj and nigel called.
Old Apr 1, 2004 | 08:01 PM
d00kee's Avatar
i would say its the head but im prolly just a "echo" fill us in if it something diffrent.
can u say go go gagit smoke screen
Old Apr 1, 2004 | 09:04 PM
kerby116's Avatar
Default Re: Smoking alote and cant find right idle in my b18b1 ls (d00kee)
its not the head cause it was working fine before i took it off. i put a b16 head on the find it had hella bent valves. than i put the ls head back on while i get funds for the new valves. thats when the problems started.so im sure its just the gasket, but im not sure about the idle
Old Apr 12, 2004 | 12:37 PM
d00kee's Avatar
how the timeing on the belt?
FTNW
Aug 17, 2012 07:59 AM
flash69
Engine Management and Tuning
Nov 23, 2008 12:25 PM
crxhondata
Jul 15, 2008 02:23 PM
westside49block
11
Feb 2, 2008 09:32 PM
akomplice
Sep 23, 2007 12:44 PM
