Valvetrain, what should i go with?
Old Oct 24, 2001 | 04:40 PM
rioninja's Avatar
Default Valvetrain, what should i go with?
After consulting a few friends, i have decided that the next time i spend a couple bucks on my car, its getting a new valvetrain (2nd gen B16a head btw). Everyone is recommending i just go with a type R setup, but my question is: what kind of cams/rpms can a stock type R valvetrain really handle? With the setup i'm thinking about i dont plan on reving much past 9k, but i dont want to kill it if i bang 10 grand once in a while. Any suggestions? If i had the money, i would definatly go with a JUN, or Crower setup. I just dont want to go overkill and wast money. I'm thinking maybe just typeR cams, with titanium retainers....
Old Oct 24, 2001 | 05:35 PM
FSTASNTZ's Avatar
Default Re: Valvetrain, what should i go with? (RioNinja)
Depends on the cams. For ITR cams, CTR cams and TODA Spec As you will be fine. Not sure about JUN cams
Jason
Old Oct 24, 2001 | 09:37 PM
da6_b17a's Avatar
New User
Default Re: Valvetrain, what should i go with? (FSTASNTZ)
sup,
the type r valvetrain will be more than enough. there's no reason for 10k if you're going to use type r cams; you'll be losing power if you do. for 9k, get type r springs, crower tit retainers(very light 6.0 grams @ $150 vs honda 11.5 grams), type r intake valves @ $125 and if that doesn't satisfy, replace the inner springs with portflow @80 to rev beyond 9k. Hope this helps you out.
Old Oct 25, 2001 | 07:23 AM
topspeed86's Avatar
The main thing to figure out is what cams but if you run toda a or b's or skunk 2 even CTR cams the best springs are Type R outers and Portflow inners rev to 9 grand all day long
Old Oct 25, 2001 | 08:04 AM
Jared's Avatar
Default Re: Valvetrain, what should i go with? (topspeed86)
defintely get tit. retainers. i know from experience that itr retainers break when used frequently to 9k.
raverx3m
Jan 31, 2013 08:40 AM
Liu Kang
Jul 14, 2008 01:03 PM
Adam.
Jan 12, 2005 03:58 AM
shadowstylz
Jul 15, 2003 08:41 AM
Atiyeh
Jul 17, 2001 12:23 AM
