LS tranny with GSR gears
Old Oct 24, 2001 | 04:20 PM
Allstar's Avatar
New User
Default LS tranny with GSR gears
i found an ls motor i'm thinkin about buyin and it has gsr gears and ls final drive. ive never seen this set up before, any downsides?
Old Oct 24, 2001 | 06:19 PM
Muglit's Avatar
New User
Default Re: LS tranny with GSR gears (squirrelmasta)
If everything is working fine then the here are the pluses and minuses
plus:
more torque to the ground than ls tranny
lower highway rpm than gsr tranny
minus:
not as much torque to the ground as gsr tranny
higher highway rpm than ls tranny
lower gearing top speed(using ls stock redline) than a gsr and a ls
I think thats it if I think of anything else I'll let you know.
Old Oct 24, 2001 | 09:41 PM
MK Ultra's Avatar
Well, 1st and 2nd gear are the same ratio for the GS-R and LS, so the gearing will only be shorter in 3rd - 5th. Not exactly how I'd do it. If you want the same final drive as the GS-R you can install the ring gear and countershaft from a B17A's tranny, or if you are willing to change the diff at the same time you can use the ring gear and countershaft of a 3rd Gen GS-R.
JDM_Certified
Transmission & Drivetrain
Jun 26, 2010 11:54 PM
Stingray96
Jan 22, 2006 08:23 PM
BoOsTiN Dc2
Jun 9, 2005 02:35 PM
Rain n Blood
Aug 18, 2004 04:51 PM
lambgsr1
Jan 16, 2003 05:14 PM
