Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
97 Cr-v problem please help!!! engine turns of and when the it warms up shuts off!!!
Old Apr 1, 2004 | 07:14 AM
1SickHb's Avatar
Default 97 Cr-v problem please help!!! engine turns off after it warms up !!
97 Cr-v problem please help........ when the it warms up shuts off!!! its my girl's moms car..... f*cking thing turns on in the mouring nicely and when the car warms up it shuts off and wont turn of until it gets cold again.......i checked the spark plug wires for any sparks but it doesn have spark??? <<but when it starts (when its cold) i check for sparks and it has??? wtf!! please any one help out cuz im tryin fix my rex while she keeps braggin her problem.........plus i changed the coil in the dizzy? and it still does the same thing??
please any one???
Old Apr 1, 2004 | 12:33 PM
TEXN3's Avatar
Default Re: 97 Cr-v problem please help!!! engine turns off after it warms up !! (si Rob)
check dist. cap and rotor, plug wires. maybe a bad tank of gas. i'm having similiar problems with my teg. it'll die or bog hard after it has started. did a tune-up and now have to run through 25 bucks of gas. kinda pisses me off.
Old Apr 1, 2004 | 05:52 PM
MIDNIGHT's Avatar
Default Re: 97 Cr-v problem please help!!! engine turns off after it warms up !! (texnteg)
could be a bad ingnitor
Old Apr 1, 2004 | 05:55 PM
1SickHb's Avatar
Default Re: 97 Cr-v problem please help!!! engine turns off after it warms up !! (MIDNIGHT)
but why wold it start so perfect
and then just die
.................then if u leave the car alone ........starts up perfect again
one of my friends said it was the module in the dizzy
Old Apr 1, 2004 | 05:59 PM
Lance88ZXT's Avatar
Default Holy ****
I came here to ask about the same damn problem! I'll just post in here instead of making a new topic: Here's the description of the almost same damn problem:
My 97 Honda CRV had a code in it for a little while, some shop said it was a distributer code (bullshit.) The thing would start dying at random while idling. I finally got around to scanning the ecm myself, and it was no TDC sensor signal. I replaced the sensor, the code still came back. Time to check wiring. So at this point I'm clueless. It sounded like a clogged fuel filter, so I replaced that. Still no go. Right after it dies while idling, it's hard to start it back up again. Is the problem with that sensor signal, or is the problem unrelated? Thanks much
Old Apr 1, 2004 | 06:30 PM
MIDNIGHT's Avatar
Default Re: Holy **** (Lance88ZXT)
when the ignittor gets hot from running its circut breaks down and then it dies. then you let it cool off for a bit it will run again. i have some old ones laying around. this happens on alot of hondas.
Old Apr 1, 2004 | 06:53 PM
1SickHb's Avatar
Default Re: Holy **** (MIDNIGHT)
ima see if its this ignitor
??? f*cking new dizzy cost way to ******* much and watch that not even be the problem!!!!!!!!!!1
Old Apr 1, 2004 | 06:57 PM
MIDNIGHT's Avatar
Default Re: Holy **** (si Rob)
any obd1 and up ignitor will work in you dizzy. so if you have a freind with a spar one pull it out and try it.
Old Apr 1, 2004 | 07:13 PM
1SickHb's Avatar
i just really hopw it stops here !!! thanks for the info tho
Old Apr 2, 2004 | 12:42 PM
Lance88ZXT's Avatar
an ignitor? what exactly is, and where is it? I'll try anything inexpensive at this point...
Old Apr 4, 2004 | 07:37 PM
B18BUUST's Avatar
sounds like ignitor
Old Apr 30, 2004 | 11:59 AM
townshow's Avatar
sometimes even cold start it would start up ok and when I put it in drive with a little gas it would die. I would have to wait a few minutes before I restart. Then it would stay running. When it dies I have no warnings and no signs. I know when it is a warm day I would have more problems. These few days was cool. So it didn't happen that much.
Old May 5, 2004 | 01:25 PM
jfastman's Avatar
Two things may be responsible for the stall. One. the ignition switch-wiggle the key and the wires at the back of the switch to see if will stall. Two, the main relay behind the right kick panel just above the PCM. I've seen alot of CRV's have problems with those two things the most.
Old May 6, 2004 | 01:07 PM
luciferi's Avatar
Default Re: 97 Cr-v problem please help!!! engine turns off after it warms up !! (jfastman)
It sounds like the same problem some g2 integras have. I think their problem is with the main pgm-fi relay. That relay shuts down the fuel pump. It would pretty simple to listen to see if the pumps energizes when the key is turned on.
If it is a bad relay, they might just need the contacts cleaned. They turn black from arcing when turned on/off over time.
gunrunner
Sep 14, 2013 06:19 AM
wicaed
Jun 20, 2012 10:18 AM
503Ryder
Dec 4, 2010 12:49 PM
Dukes69
May 13, 2007 12:44 PM
mugen97ek
Jul 22, 2005 08:30 PM
