radiator hoses , how to get off???
Old Apr 1, 2004 | 07:12 AM
WRTEG's Avatar
Default radiator hoses , how to get off???
i can't seem to get the hoses off my radiator, and i don't want to rip the hose, any way or prying them off without ripping them or something to apply to it???
Old Apr 1, 2004 | 07:28 AM
Audi A4's Avatar
Default Re: radiator hoses , how to get off??? (94IntegraNL)
just tug on it.. there hard to break... why are u taking it off anyways?
Old Apr 1, 2004 | 07:46 AM
quikB18B's Avatar
Default Re: radiator hoses , how to get off??? (DRAG lll INTEGRA)
Try tugging it realy hard, because of the pressure these can be a Pita to gte off sometimes.
Another trick to try is use some big plyers or something and clamp it around the hose , carefull not to break to outlet underneath, and just turn it from side to side slowly coming out. Once you break it free you should be able to easlily remove it.
Do it gently though you don't want to break anything, all your really need to do is spin the hose so it comes loose.
Old Apr 1, 2004 | 07:50 AM
DAsix's Avatar
haha. I tugged on my 91 awhile ago and the radiator casing crumbled apart on me as well as the hose. That sucked.
Old Apr 2, 2004 | 04:59 AM
WRTEG's Avatar
I got it off, was replacing my radiator, just end up using a flat top screw driver and pryed it around abit, then starting turning the hose and it came off pretty easy
Old Apr 2, 2004 | 08:38 AM
Devlins 91LS's Avatar
Default Re: radiator hoses , how to get off??? (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">all you really need to do is spin the hose so it comes loose.</TD></TR></TABLE>
werd
Everyone just pulls the damn thing to hell, and thats when **** breaks / the hose finally gives way, you smack the **** outta ur hand, and then start swearin kickin ****.
Old Apr 3, 2004 | 02:48 AM
{Mineral Grey} ITR's Avatar
Default Re: radiator hoses , how to get off??? (Devlins 91LS)
I used the pulling-cursing-twisting method
Old Apr 3, 2004 | 04:12 AM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">Try tugging it realy hard, because of the pressure these can be a Pita to gte off sometimes.
Do it gently though you don't want to break anything, all your really need to do is spin the hose so it comes loose.</TD></TR></TABLE>
That's what I do....give it a twist to break it loose and then pull. If the hose underneath is compromisable, then I just slit it with a razorblade and buy a new one.
Old Apr 3, 2004 | 04:59 AM
Dan GSR's Avatar
Default Re: radiator hoses , how to get off??? (IN VTEC)
get some channel locks
grab the end gently, and twist side to side to break the seal
Nocturnal
Dec 1, 2005 11:58 AM
Slvr_CRX
Apr 8, 2004 09:03 AM
goforbroke
Jan 21, 2003 07:59 AM
