What equipment do I need to paint in my garage? (searched)
Old Mar 31, 2004 | 11:06 PM
dmbmalaka's Avatar
Default What equipment do I need to paint in my garage? (searched)
https://honda-tech.com/zerothread?id=818636
wasntt sure what forum to put this into. I'm not showing anything off so i would guess that is would be tech, but exterior. not sure, but i could use some help... thanks in advance
Modified by fordSuck at 3:22 AM 4/1/2004
Old Apr 1, 2004 | 02:40 AM
Eyes Only's Avatar
Default Re: What equipment do I need to paint in my garage? (fordSuck)
also curious about this subject
Old Apr 1, 2004 | 02:53 AM
s2kds's Avatar
I'll get back to you after 3:00 (saved in recent topics) i did mine a few months ago.
Old Apr 1, 2004 | 06:49 AM
Awar318's Avatar
Default Re: What equipment do I need to paint in my garage? (delsol8694)
Old Apr 1, 2004 | 07:57 AM
allmotaeg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fordSuck &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=818636
Modified by fordSuck at 3:22 AM 4/1/2004</TD></TR></TABLE>
all you would need is something to cover up the walls of your garage to protect from overspray,something to vent all the fumes,a good face mask not the cheap paper mask either,2 guns 1 for the primer and 1 for the base and clear coat,and a good compressor i would go with the craftsman 60 gal which would be a pretty good investment cause you can use it for anything else around the house or automotive heres a link to it http://www.sears.com/sr/javasr...19000
Old Apr 1, 2004 | 11:16 AM
s2kds's Avatar
Default Re: What equipment do I need to paint in my garage? (pr0ject Eg6)
I painted my del sol over christmas break. The prep work is 80% of it. Here is a list of stuff i had to buy. The list excludes the paint gun and small every day stuff we had in the garage. I would Highly recomend finding some one who has done many cars before, but if you dont have any... pratice on some old sheet metal first. If you have any question about what the things are on the list let me know.
Also, sorry for the size but if i shrink it down it is even harder to read! I know its hard to read already. i can remove it if any one has a problem w/ the size.
Old Apr 1, 2004 | 11:19 AM
pdiggitydogg's Avatar
the hell does that say???
s2kds's Avatar
WOW shitty:
Here they are in order:
dusk mask
gold tack cloth
spreaders
masking tape
epoxy primer
actriator
paint
clear coat
reducer
stablizer
activator
pearl
thinner
sorry for the bad pic
Old Apr 3, 2004 | 01:06 PM
dmbmalaka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol8694 &raquo;</TD></TR><TR><TD CLASS="quote">WOW shitty:
dusk mask
gold tack cloth
spreaders
masking tape
epoxy primer
actriator
paint
clear coat
reducer
stablizer
activator
pearl
thinner
What compressor and gundid you use? How did you vent the area?
Old Apr 5, 2004 | 07:11 PM
s2kds's Avatar
We used a gravity gun, a big *** compressor...i would gues like 100+ gal. and a down draft sys. in a paint booth.
Like i said it pays to have good friends.
not sure how you would vent your garage. sorry.
Remember every thing has to be clean! and stay clean
Old Apr 5, 2004 | 07:17 PM
99blackcivicSi's Avatar
Painting in a garage sucks, find somewhere to rent a booth i see too much dirt and **** in the paint when it is painted in a garage down draft is the only way to go !
Old Apr 6, 2004 | 02:02 PM
dmbmalaka's Avatar
Default Re: What equipment do I need to paint in my garage? (99blackcivicSi)
Old Apr 6, 2004 | 02:20 PM
pakman2002's Avatar
I primered my front bumper in my garage. It blew nukin futs. I got lil debris of dog hair and dirt in the paint even though i tried sealing a box off in my garage with visquin and cleaned throughly. If i was u i would try to find a booth. Like every body said down draft is the way to go
Old Apr 6, 2004 | 02:52 PM
Yeung's Avatar
Default Re: What equipment do I need to paint in my garage? (pakman2002)
to minimize dust.. you can wet the floor with water first..
by wetting the floor you also prevent paint from sticking to the floor..
Old Apr 6, 2004 | 02:54 PM
foz's Avatar
foz
can someone refresh my memory, I think I know, but am not sure
what's the downdraft system?
Downdraft<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol8694 &raquo;</TD></TR><TR><TD CLASS="quote">a down draft sys. in a paint booth.
Old Apr 6, 2004 | 02:55 PM
Ricey McRicerton's Avatar
Default Re: What equipment do I need to paint in my garage? (Yeung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yeung &raquo;</TD></TR><TR><TD CLASS="quote">to minimize dust.. you can wet the floor with water first..
by wetting the floor you also prevent paint from sticking to the floor..</TD></TR></TABLE>
This man speaks the truth. If you can hang tarps all over and wet them down it helps keep the dust down a lot.
This said, I'd wait a month to paint in a booth rather than paint in a garage.
Old Apr 6, 2004 | 03:17 PM
Run Hatch's Avatar
Default Re: What equipment do I need to paint in my garage? (Ricey McRicerton)
Rent a booth do all the prep work at home and go to the booth and just spray. GOOD LUCK
Old Apr 6, 2004 | 04:27 PM
s2kds's Avatar
Default Re: What equipment do I need to paint in my garage? (foz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foz &raquo;</TD></TR><TR><TD CLASS="quote">can someone refresh my memory, I think I know, but am not sure
Downdraft
Down draft sys. is a constant air moving sys. it brings in fresh filtered air and get rid of old paint and active dust. It is the best way to go.
Old Apr 6, 2004 | 04:47 PM
Down draft sys. is a constant air moving sys. it brings in fresh filtered air and get rid of old paint and active dust. It is the best way to go. </TD></TR></TABLE>
And does so by pulling all of the air in the booth down. It keeps dust down too.
Old Apr 6, 2004 | 05:05 PM
foz's Avatar
foz
right, that's what I was thinking but wasn't sure if it was the same....
had a ghetto version hooked up in my buddy garage to paint an old chevy nova, took the windows out and replaced with box fans w/filters from the body shop he worked at, and set up a row of them along the bottom of the garage door as exhaust fans (holding the door up) we borrow big box fans from everyone we knew, a couple girls were pissed when they came back "indiglo blue" the blue color chevy was using on trailblazers and trucks the last couple of years....
it worked pretty good, only dirt that ended up in paint sanded and buffed out easily..
Old Apr 9, 2004 | 02:49 PM
dmbmalaka's Avatar
well i have a big garage (not like attacthed to house, like mechanics garage) with an extra room off the side, how could i turn this into a painting room? just tarp the walls, vent, wet, and keep extremely clean?
Old Apr 13, 2004 | 04:15 PM
s2kds's Avatar
yes, but make sure your venting sys. is the best you can afford. And CLEAN in the key.
Old Apr 13, 2004 | 04:27 PM
Code Blue's Avatar
i have personally seen the box fan trick work, but you need to wet the floors, and try to use paper to mask off the walls. also you want to make sure the air supply your getting to your gun is clean and not filled with water and oil, you also want to make sure you get all traces of anything oily away from the ENTIRE painting area, clean that **** good. it will fisheye like a ****. I work in a body shop, so i dont have to worry about the ghetto tricks ( have a $150k spray booth with down draft and heat to bake it) ventilation and a clean airsource are key, this isn't like spraying your valve cover with spray paint, you can die from paint fumes, this stuff is nasttttty
bizenboat
Jan 5, 2008 12:18 PM
B18CivicEH2
Dec 13, 2006 08:58 AM
BeckzCiviC
15
Mar 15, 2005 08:09 PM
bambooluv
Jan 17, 2004 10:47 PM
Smoochy
Mar 25, 2003 02:50 PM
