twin turbo, bi turbo, two turbos......
Old Mar 31, 2004 | 10:37 PM
Rabid Machina's Avatar
Default twin turbo, bi turbo, two turbos......
how ever you may want to call it is it possible on the prelude or will it work? i know there is only so much exhaust gases that flow through the manifold was just wondering if i can make it happen.....imput is appreciated.
Old Mar 31, 2004 | 10:45 PM
TeamCracka's Avatar
Default Re: twin turbo, bi turbo, two turbos...... (calilude)
It's been done, but isnt pratical at all really.
They're more commonly used with a small turbo to spool at low RPMs, and a larger turbo to take up the higer part of your power band. You're better off getting a T3/T4 turbo and having lag until around 3000-4000rpms. It'll be ALOT cheaper and you wont have all the headaches with hooking both turbo's to an intake, exhaust, and TWO wastegates!
Someone did a TT setup on homemadeturbo.com try searching the forums over there.
street_ride14
Jun 21, 2008 09:27 PM
donpeters
Dec 6, 2004 08:21 AM
fast94ex
Oct 8, 2004 01:02 PM
