Why does the car run rich during warm up? How is that hotter?
Old Mar 31, 2004 | 09:54 PM
sporkcrx's Avatar
Default Why does the car run rich during warm up? How is that hotter?
When cars are started cold, it runs rich to warm up faster than if it's running near stoich. How the hell does this warm the engine up faster? It seems like the closer to to lean it is the hotter it would be running?
Old Mar 31, 2004 | 10:09 PM
blueeg's Avatar
Default Re: Why does the car run rich during warm up? How is that hotter? (sporkcrx)
more fuel is going into the engine which makes it easier to start especially in the cold mornings. more fuel means your engine is working faster thus creating more heat.
Old Apr 1, 2004 | 05:06 AM
JimBlake's Avatar
Default Re: Why does the car run rich during warm up? How is that hotter? (blueeg)
You need stoichiometric mixture to burn OK, but any liquid that doesn't evaporate doesn't count. So for example when the engine's cold maybe only 80% of the fuel actually evaporates. So you inject 25% extra, in order to get the PROPER amount that's actually evaporated.
Old Apr 1, 2004 | 07:50 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">When cars are started cold, it runs rich to warm up faster than if it's running near stoich. How the hell does this warm the engine up faster? It seems like the closer to to lean it is the hotter it would be running?</TD></TR></TABLE>
A cold engine is richened up so it runs better. It doesn't have anything to do with warming it up faster.
Old Apr 1, 2004 | 10:11 AM
sporkcrx's Avatar
Default Re: Why does the car run rich during warm up? How is that hotter? (Chiovnidca)
ahhhh I gotcha. Is it the heat from the moment the fuel exits the injector that vaporizes it that quick?
fleabag
Feb 26, 2010 04:28 PM
zirac50
Mar 23, 2007 10:28 PM
maxamusprime
Jan 21, 2007 02:30 PM
DSR!
Oct 24, 2004 06:26 PM
