obd1 h22 into 96 accord lx, wiring info needed ASAP
alright im running into a weird problem. i have an jdm prelude fornt cut, obd1 the distributor has an internal coil. there are 2 plugs on the dist. one with 2 wires, the other has 7. the wiring harness from the 1996 accord which is factory equipped with an external coil. 2 plugs as well, 2 and 4 wires each. thats where the prob starts.. i know the crank angle sensor is external on the obd2 but the wire colors do not match...
any ideas on how to wire this thing up, or can i get a prelude or obd1 engine bay harness and plug it into the 96? anyone.. any idea?
im using a obd 2 to 1 conversion harness for the ecu, is there a obd1 distributor with external coil that fits the h22, if so from what. i could just wire in the crank angle sensor to the fact harness?.
Modified by kawgomoo at 11:05 PM 3/31/2004
how the hell did you do that? the bolt pattern is nowhere close... and its shy a sensor. which are different in config from the prelude ones.
wait, i'm trying to remember how we did it...we might have used the internals of the obd2 distributor inside the prelude distributor...i'll have to check on it tomorrow...
will do...i'll try to snap some pics if i can...i know that my swap was the biggest bitch in the world, and have since tried to forget it...lol...actually, it's been about a year ago now, and i've drunk a lot since then...
everytime i do a h22 swap its a pain in the ***...
ive got it down now, but i never ran into the obd2 and distributor thing before..
we had the problem. in my 96 accord and it was 96 dizzy
i ended up doing the swap..
you can find how to do the internal to external and vice versa swap on collective racing and accordinglydone.com tech sectoin
i think we used the inside of the b18 and shell of another.. it was a PIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kawgomoo »</TD></TR><TR><TD CLASS="quote">alright im running into a weird problem. i have an jdm prelude fornt cut, obd1 the distributor has an internal coil. there are 2 plugs on the dist. one with 2 wires, the other has 7. the wiring harness from the 1996 accord which is factory equipped with an external coil. 2 plugs as well, 2 and 4 wires each. thats where the prob starts.. i know the crank angle sensor is external on the obd2 but the wire colors do not match...
Modified by kawgomoo at 11:05 PM 3/31/2004</TD></TR></TABLE>
Could someone help us out?
congrats! i'm at the EXACT SAME PROBLEM right now with my 97 car. i gotta distributor wiring diagram i'll send ya in a few hours when i get to work. i haven't tried that myself yet but a fellow ht'er sent it to me this morning and it should be the solution to our problems.
*Edit NVM i just uploaded it... here's the pic. Good luck with it, i hope both our cars work out.
that looks great and all, but the obd2 plug there has 6 wires. the accord lx harness that came in the car only has 4 wires in the big plug and 2 in the dist. power plug...
do i need to get a diff harness? remember im using a jdm motor.. so i cant reuse the harness.
like i said... i'll have to let u know when we do it... right now work and school owns me so tonite or tomorrow nite i'll find out my answer.
FYI i'm using the F22b2 Harness to a JDM 1994 H22a motor.
ok im completely retarded... but the colors had me all jacked up, it was late and i had one bonghit too many...
anyhoo thanks koncepts and bionic.. yall cleared it right up for me.
i used the 96 accord harness, cut all the loom off it, put an obd1 plug on the harness, pinned in teh wires, cut all the loom off the harness pulled the crank angle wires back over to the disttributor cut them to the right length and pinned those in as well... retaped teh harness and reloomed it. shes good to go... looks like factory.. no one will ever know.
thanks again everyone.. i took pics of the process if anyone gets stuck in the future.
hey man... please e-mail me the pics at Typerkoncepts@aol.com if you could. I'd love to be able to cross referance in case something came up. Also which conversion harness did you use for the ecu side? or did u just use obd 2 ecu?
At this very moment, I'm throwing code 9 and the car sputters throughout the rpm. I don't think the wirings is done incorrectly. Could the ignition timing be off?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- »</TD></TR><TR><TD CLASS="quote">At this very moment, I'm throwing code 9 and the car sputters throughout the rpm. I don't think the wirings is done incorrectly. Could the ignition timing be off?
Thanks</TD></TR></TABLE>
could be , whats code 9?
remember in obd2 the time is auto adjusted by the ecu
when going to obd1 its more of a manual adjust
only small problem, is that the dizzy is kinda fixed on obd2 cause its done by the comptuer, so you cant move it all that much
rorik
Aug 18, 2016 04:51 PM
DigitalPunk
Jul 27, 2013 12:53 PM
MPower332TI
Jun 18, 2003 01:18 AM
