Brake Light on dash ON although all brake lights are working
Old Mar 31, 2004 | 07:15 PM
makaveli_0000's Avatar
Default Brake Light on dash ON although all brake lights are working
What's up with the brake light indicator on the dash? It remains on all the time even though all my brake lights are working as the should.
Any fuses I should be checking?
Car is a 91 Accord EX-R.
Thanks.
Old Mar 31, 2004 | 07:39 PM
solo2slocivic's Avatar
Default Re: Brake Light on dash ON although all brake lights are working (makaveli_0000)
check the plugs for the sensors at each tail light... the slightest corrosion can cause that problem
Old Mar 31, 2004 | 07:41 PM
Atheist's Avatar
I would bet you are low on brake fluid. Fill up the resovior with some dot3 approved and you'll be good bro
Old Mar 31, 2004 | 07:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makaveli_0000 &raquo;</TD></TR><TR><TD CLASS="quote">What's up with the brake light indicator on the dash? It remains on all the time even though all my brake lights are working as the should.
Thanks.</TD></TR></TABLE>
well i guess we should be asking wich light is on.....
one of us has the correction....
Old Apr 1, 2004 | 10:59 PM
cha chi's Avatar
Default Re: Brake Light on dash ON although all brake lights are working (solo2slocivic)
yep check the fluid and top it off. also check the cap on bottle and floats.. someone also had a probelm with the switch which was causing the light to stay on all the time. i still say brake fluid
Old Apr 2, 2004 | 04:33 AM
The_Todd's Avatar
Farts in the shower
Default Re: Brake Light on dash ON although all brake lights are working (cha chi)
If its the same light that goes on when your ebrake is on...its a problem with your brakes (check fluid etc etc). If its the one in the car diagram, its a burnt out tail light, also double check the double filament bulbs (which is all but your 3rd brake light ).
Old Apr 2, 2004 | 11:10 AM
EX-JAY's Avatar
Default Re: Brake Light on dash ON although all brake lights are working (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">If its the same light that goes on when your ebrake is on...its a problem with your brakes (check fluid etc etc). If its the one in the car diagram, its a burnt out tail light, also double check the double filament bulbs (which is all but your 3rd brake light ).</TD></TR></TABLE>
Old Apr 13, 2004 | 08:04 AM
sp00led's Avatar
Default Re: Brake Light on dash ON although all brake lights are working (EX-JAY)
Not sure if weather has anything to do with it but I had the exact same problem this morning on my 99 GSR. A cold front came through last night and this morning it was 36F. I left for class and on the way notice the e-brake light was still on. It would go away anytime a pressed the brake firmly. On the way home the light never came on but when I checked the fluid it was about a 1/2 below the max fill line. Going to store to snag some fluid on the way to next class. Pretty sure this was the cause and fluids is the fix. (Checked all 4 pads last weekend they appeared to have atleast 50% left.)
Old Apr 13, 2004 | 09:26 AM
.bagged's Avatar
thank you ... I was getting a head ache...
SpazMan
Jun 22, 2009 08:44 PM
EASY101
Jul 10, 2006 02:26 PM
AdamDavidDoyle
Sep 11, 2004 08:36 AM
ilikemyaccord
Jun 13, 2004 09:16 PM
Bishop Don Shizzle
Jan 2, 2004 06:23 PM
