What are the symptoms of a failing slushbox?
Old Mar 31, 2004 | 06:51 PM
makaveli_0000's Avatar
Default What are the symptoms of a failing slushbox?
Here are my symptoms:
1. When shifting from P to N, D4 or D3, car surges.
2. When shifting from D4, D3 or N to P, car surges.
3. When driving in D4, shifting is a little strained (delayed?) especially from 1 to 2 and 2 to 3.
4. Similar delay is noticed during downshifts.
Will this be caused by too much oil in tranny? If draining and re-filling does not resolve problem, how much should I budget to swap in a used slushbox? How reliable are these slushboxes anyway?
Car is a 91 Accord EX-R.
Thanks.
Old Mar 31, 2004 | 06:57 PM
fw190bvi's Avatar
Default Re: What are the symptoms of a failing slushbox? (makaveli_0000)
honda AT usually suck ***, and shift "hard" as they age......are u using the right viscosity tranny fluid???
Old Mar 31, 2004 | 07:17 PM
Default Re: What are the symptoms of a failing slushbox? (fw190bvi)
I cannot tell if the right fluid is in there but I am scared to the ***** to flush the slushbox.
I flushed the slushbox in a good working BMW transmission and it headed south.
Old Mar 31, 2004 | 07:36 PM
solo2slocivic's Avatar
just change the fluid. drain and fill...2.5 qts of honda atf-z1...the car does not have an internal filter... if you use trans fluid other than hondas you possibly may not correct the problem.
Old Mar 31, 2004 | 08:49 PM
John Gordon's Avatar
I have 260K miles on an AT. Key is flush every 20-30K miles. If the fluid is fresh and you still have problems, then take it to someone you trust (get references).
Old Mar 31, 2004 | 08:51 PM
iam7head's Avatar
Default Re: What are the symptoms of a failing slushbox? (John Gordon)
the thing is that everytime you flush your tranny, you only getting 3/4(sometime less or more) atf out, a bunch of old oil is still in the torque converter.
10-20k for a flush and refill with honda oem stuff might just can save you a transaxle
another thing to look for went buying an automatic equipped car is by looking at the dipstick, if there's little black, tar like particle on top of the dipstick, the chances are, the tranny is loosing the clutchpack.
if it would shift now, sell it. Because it wouldn't shift much longer
rollings42
Jun 8, 2017 06:26 PM
gauravsoni00
17
Sep 2, 2013 04:59 AM
Muggz494
Honda Civic (2006 - 2015)
Feb 11, 2010 03:37 PM
916B18c1
Jun 30, 2008 04:22 AM
Paprika
17
Jun 27, 2006 11:55 PM
