"whhhhhiiiinnnnnggggg" (noise)
Old Mar 31, 2004 | 06:31 PM
birz's Avatar
Default "whhhhhiiiinnnnnggggg" (noise)
ok I'll explain it briefly:
My engine (B18B1) has just been built (Ross pistons+ Eagle rods) every single gasket is brand new, new oil pump, new timing belt, new rod and crank bearings, BUT I didnt make change the water pump I know it's lame from me but my engine builder told me that it was good, no leaking at all, and I was really short on cash. But now it's been like 500KM I'm driving the car and there's always a funny noise like a strap and it looks like it comes from the timing belt area. The noise is RPM dependant, I can hear it at idle and throughout the whole RPM band. it's like a "winding" high pitch , a strap related noise. it's kinda hard to explain it by words. there's no leak anywhere, so I want to know what could be the cause???
- timing belt too tighten?
-alternator?
-water pump?
-power steering belt?
-anything else?????
please answer me, thanks
Old Apr 1, 2004 | 05:29 AM
birz's Avatar
Default Re: "whhhhhiiiinnnnnggggg" (birz)
anyone??? should be an easy one for you guys, plz
Old Apr 1, 2004 | 05:31 AM
tony1's Avatar
Sounds like possibly the timing belt is too tight.
Old Apr 1, 2004 | 05:58 AM
DaveF's Avatar
Default Re: "whhhhhiiiinnnnnggggg" (tony1)
possibly the cam caps as well.
Old Apr 1, 2004 | 09:12 AM
m R g S r's Avatar
Default Re: "whhhhhiiiinnnnnggggg" (Dturbocivic)
How many miles were on your stock water pump?
Old Apr 1, 2004 | 09:34 AM
G
sh!t happens.
Default Re: "whhhhhiiiinnnnnggggg" (m R g S r)
i think ur timing belt is to tight...
Old Apr 1, 2004 | 09:36 AM
turbo89civicb18hatch's Avatar
it is probobly the timing belt cover rubbing on the cam gears or belt or water pump
Old Apr 1, 2004 | 09:48 AM
birz's Avatar
Default Re: (turbo89civicb18hatch)
I hope it's the timing belt being too tight. How do I know if it is too tight??
Old Apr 1, 2004 | 09:52 AM
G
sh!t happens.
Default Re: (birz)
it makes a nosie or just fill the belt youll know if its to tight.
Old Apr 1, 2004 | 09:59 AM
Turbo E's Avatar
timing belt
Old Apr 1, 2004 | 10:16 AM
birz's Avatar
Default Re: (G"UNIT)
if I feel the belt how tight it should be? should I be able to turn it a bit or not??
I'm new to timing belt feeling.
Old Apr 1, 2004 | 10:44 AM
Nextelbuddy's Avatar
Default Re: (birz)
my firends did the same thing whining noise and was rpm dependent. we loosend the timing belt and it went away
Old Apr 1, 2004 | 10:47 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (birz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birz &raquo;</TD></TR><TR><TD CLASS="quote">if I feel the belt how tight it should be? should I be able to turn it a bit or not??
I'm new to timing belt feeling.</TD></TR></TABLE>
Just reset your timing belt tension. Loosen the tensioner bolt, rotate the engine a few degrees, tighten the tensioner bolt.
NathanDC4
Mar 27, 2016 11:43 PM
the.hamburglar
Apr 22, 2007 04:52 PM
importfanatic17
Dec 3, 2006 04:39 PM
dornon13
Oct 3, 2005 09:45 AM
Drew96EJ
Oct 30, 2003 01:48 PM
