fuel filter bolt......
I'm trying to find the part number to the Bolt that holds the line from the car into the fuel filter so that I can search some of the local shops to see if they have em. Dose anyone know if it’s the same on any other car. Because when go to http://www.hondaautomovtiveparts.com and bring up the fuel pipe section it has the wrong picture it has the picture of the transmission up. If I go to the integra it has the picture up but I’m not sure if there the same thing. And from what I see the 2 bolts that hold the 2 lines in are different. Dose anyone know if that’s true or not. Here is a picture of the bolt that I am missing.
I cant seem to find it anywhere. but on shop says i need something called a bolt, sealing 12mm and others say that i need banjo bolt. so not sure which one i should order?
Usually when you go to the honda dealership, they can pull up a diagram for the fuel line and filter assembly to find out the part number. It shouldn't cost more than 20 bucks there.
I have the diagram and it says that the line that goes to the engine needs a banjo bolt and a bolt sealing that goes into it. and the one that goes from the car filter to the car needs just a bolt sealing... but on my car that one has the banjo bolt thats whats confusing. the diagram says differnt then what my car has.
http://slhondaparts.com is better, clickable pics and part numbers.
http://slhondaparts.com/browse.asp?M...ViewParts=true
you're missing #28 and #27, click on the numbers for the part#.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eggman »</TD></TR><TR><TD CLASS="quote">http://slhondaparts.com</TD></TR></TABLE>
Nice site, I only looked up a part I needed but it seems awfully expensive. Oh well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Usually bolts are free at a junkyard.
true that .. i mean never done it or anything like that .. i huuuuurd
calvin924597
May 28, 2010 09:55 PM
