camber kit needed with tein ss coilovers ??
Old Mar 31, 2004 | 04:32 PM
1hotintegra's Avatar
Default camber kit needed with tein ss coilovers ??
im gettin tein ss coilovers for an 04 rsx... with adj. pillowmount.. is a camber kit necessary?? only about a 1.5 inch drop? i know it is needed with reg. springs but what aabout with adj. coilovers?
Old Mar 31, 2004 | 06:38 PM
civicvtec1ps's Avatar
Default Re: camber kit needed with tein ss coilovers ?? (1hotintegra)
Just get rear camber kit.
But its not necessary, camber kit won't hurt you in long run.
Old Mar 31, 2004 | 06:55 PM
Desert Storm's Avatar
Only for rear I believe.
Old Mar 31, 2004 | 08:43 PM
ZTYPE_S's Avatar
You should get a camber kit, but if you like to spend money on tires ( especially on rear tires) then dont get a camber kit. i recently got my car lowered on some tein springs (s-tech), and I could already tell that my back tires are butterflying which will eat up my tires from the inside.So my suggestion is to get a camber kit
Old Mar 31, 2004 | 10:02 PM
DC5 03's Avatar
Default Re: (ZTYPE_S)
Lower more 1.5", you'll almost definitely will need a camber kit on the rear....That would probably be the outer edge of the range for not needing any adjustment to keep within factory specification.
Old Apr 1, 2004 | 02:36 AM
JDMCIVIC's Avatar
Default Re: (DC5 03)
if your going to slam it your going to need a camber kit. Its not that expensive and wont hurt you anyways
Old Apr 1, 2004 | 06:21 AM
Default Re: (JDMCIVIC)
.y only for the rear?
Old Apr 1, 2004 | 07:26 AM
DC5 03's Avatar
Default Re: (1hotintegra)
With reasonable change in front ride height, the front camber will typically stay within range. Maybe someone else can shed light on the threshold for needing a front camber adjuster, as I've never been low enough to make a significant change in my front camber settings. As far as I know, for a streetable ride height, you'd run some kind of camber adjustment to obtain negative camber, not so much correcting it back to within range...like I said, maybe someone can answer this better.
Old Apr 1, 2004 | 08:10 AM
ITR_1211's Avatar
camber adjustments are made on the upper pillowmounts on the fronts.
Old Apr 2, 2004 | 09:54 AM
hellrazr1208's Avatar
i'm runnin tein ss in my dc5, no need for a camber kit, and i can't even get a pinky in above the tire... so close to tuckage
Old Apr 6, 2004 | 11:23 AM
krystar's Avatar
yer supposed to use a rear camber kit though. firedc5 had his tein ss's installed and didn't have a camber kit. his rear wheels were like // \\ until he ordered one and installed it.
Old Apr 6, 2004 | 01:02 PM
f1nal zeros's Avatar
The front camber kit is not needed due to the fact the Mac struts are used.
The rear requires the camber kit due to the fact that Double Wish bone is on the rear.
If you are running the Tein SS you will not need a camber kit if you only plan to go 1.5 inchs. I am currently running the Tein Flex on my RSX-S and I have a camber kit in the rear due to the fact I am lowered a bit past 1.5.
Old Apr 7, 2004 | 01:45 PM
allmotor-s's Avatar
Yep, gotta get the camber kit for the rear. Unless you wanna rub your rear tires all damn day.
01bb6boy
Jul 9, 2011 07:11 PM
capone05
14
May 8, 2007 01:39 PM
ramz7887
Jul 21, 2005 10:24 AM
fluxcapacitor3000
Mar 2, 2005 11:25 AM
