HIDs on DA JDM 1pc
i have HIDs in the jdm 1 piece headlights.. the beam is horrible and its just really bright all over the place... i would recommend doing a projector retrofit.. someone on honda-tech did a s2k projector retrofit into the JDM 1 piece lights.. i forgot his name though.. sorry
It works just fine. But if you get hid's that have bulbs meant for projector housing you have to buy some for reflector housing. You can get them for around 100 on ebay. I cant remember what bulb it is though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain »</TD></TR><TR><TD CLASS="quote">d2r must and i stress must make a glare shield. i went through all the hassle and will soon retrofit some 5 series bixenons in my 1 pc </TD></TR></TABLE>
Hey slain I would like to know what you did to install yours and if its even worth the hassle after your done. I got a set for free from a 7 series and am planning on using them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ru2slo »</TD></TR><TR><TD CLASS="quote">sure i think this is possible.. as long as they're projectors and not the OEM JDM 1pc..
someone correct me if im wrong.</TD></TR></TABLE>
Definitely gonna need some hid projectors or you're going to be blinding the **** out of people.
I have the whole Audi bi-xenon projector setup and a pair of JDM 1-piece lights. I still haven't started on the project because of school.
You can put a HID bulb in there, but it will light up all over the place, there's a way to shield the top of the bulb so it doesn't shine all over but it's still not effective.
What I'm going to do is open up the lights and get rid of the reflector. Then, i'm going to make the hole in the back of the lights to put the projector in. I'm worried about the aiming of the projectors though. I know how it's supposed to look, the cut-off but how would I be able to adjust the projectors? I'll figure it out though. Also, the lens cover on the headlights has those flutes in it. They need to be removed from sanding, there's a tutorial in hidforum, just gotta search. If you don't make the lens clear then the cut-off won't be sharp.
The name of the dude who used the s2k projectors: theintegraguy.
someone please explain this glar gaurd a little more.. I recently installed 1pc projectors on my 2gen ls. THe stock bulbs that came with the projectors were a decent white and werent too brite.. then one went out so i had to replace both bulbs.. my brother found some silverstars or something like that so i went ahead and installed them.. now i seem to be ligthing up the trees n all the signs around me.. the signs n stuff is no big deal however i get flashed quiet often by oncoming traffic.. sorry
.. i was hoping to get some REAL HIDs soon but didnt wanna encounter the same problem.
The casper shield is actually a product made by casper electronics. Its used as an adapter for D2r or D2s capsule to fit a h4 application. What a casper shield does is block out light from shining from the bottom of the capsule to parts of the reflector that aim upwards causing glare. these are only for h4 applications. now people have copied their own version of shields for numerous other bulb fittings ie.( 9006 etc.) some work well some don't. remember you are throwing hids in a housing made for halogens. I've messed around for hrs experimenting with shields for my 1peicers still disappointed. In the process of retrofitting 5 series bi xenons in the near future.
MR Dan
Jan 13, 2005 06:38 AM
