Timing belt wont tighten, what the hell is going on? NEW BELT!!
Old Mar 31, 2004 | 01:16 PM
JSPECHB's Avatar
Default Timing belt wont tighten, what the hell is going on? NEW BELT!!
Z1 (VX) Block
Z6 (EX) Head
VX Timing Belt
My timing belt WAS tight, then it got loose. Its not tightening and the tensioner is all the way tight! This is the only thing stopping me from driving now and its pissing me off. Maybe I didnt do it right? Got any suggestions?
Old Mar 31, 2004 | 01:24 PM
temp's Avatar
Default Re: Timing belt wont tighten, what the hell is going on? NEW BELT!! (JSPECHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECHB &raquo;</TD></TR><TR><TD CLASS="quote">Z1 (VX) Block
Z6 (EX) Head
VX Timing Belt
why did you not use a Z6 timing belt? and are you sure the tensioner bolt is not stripped or your tensioner is actually functional?
Old Mar 31, 2004 | 01:30 PM
JSPECHB's Avatar
Default Re: Timing belt wont tighten, what the hell is going on? NEW BELT!! (temp)
The Z6 belt was WAY to big. Did you ever see the tensioner on a VX block? Its like the size of a half dollar. The VX block is a 1.5. The bolt isnt stripped because it gets snug and stops turning. I dont want to force it and snap the bolt inside the block because then I'm really fucked. The tensioner is working because when I tighten the bolt the belt gets tight.
Old Mar 31, 2004 | 01:34 PM
EP3_05's Avatar
Did you tighten it according to a service manual's method:
Old Mar 31, 2004 | 01:54 PM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECHB &raquo;</TD></TR><TR><TD CLASS="quote">The Z6 belt was WAY to big. Did you ever see the tensioner on a VX block? Its like the size of a half dollar. The VX block is a 1.5. The bolt isnt stripped because it gets snug and stops turning. I dont want to force it and snap the bolt inside the block because then I'm really fucked. The tensioner is working because when I tighten the bolt the belt gets tight.</TD></TR></TABLE>
so it gets tight or it doesnt?? how does it get loose?
Old Mar 31, 2004 | 04:19 PM
JSPECHB's Avatar
Default Re: Timing belt wont tighten, what the hell is going on? NEW BELT!! (JCracer723)
I fixed it. I loosened the tensioner and rotated the crank about 4-6 teeth counter clockwise to take away the slack and tightened the tensioner.
Old Mar 31, 2004 | 04:23 PM
JCracer723's Avatar
how much slack did u have??
u also mention it was getting loose after it was tight?? how was it gettin loose?
Old Mar 31, 2004 | 08:27 PM
JSPECHB's Avatar
It had alot of slack. Put it this way, when the car was running the belt was smacking the motor mount.
sohchatch
Dec 26, 2020 11:32 PM
dcwoodard
Oct 5, 2008 05:29 PM
Ignitecivic
Apr 1, 2004 02:03 PM
JSPECHB
14
Mar 31, 2004 08:26 PM
BauleyCivic
Jul 5, 2003 03:09 PM
