b16 vtec
Old Mar 31, 2004 | 11:19 AM
limpy's Avatar
Default b16 vtec
I have a b16 in my crx and I just wanted to know if I should be able to feel it pull when vtec engages? I can hear it... but i feel nothing. All of the internals are stock, if that makes a difference. any help would be appreciated.
Old Mar 31, 2004 | 11:22 AM
92b16vx's Avatar
B16A in a rex should romp once it hits vtec.
Old Mar 31, 2004 | 11:26 AM
limpy's Avatar
Default Re: (92b16vx)
That is what i am told but it has no pull. you can clearly hear it kick in but the damn thing just doesn't get up and go.
Old Mar 31, 2004 | 11:46 AM
TIRENECK's Avatar
Default Re: (limpy)
you expect a pull like F&F when they hit nos(muahahah)? u will not feel anything when vtec engages, only hear it.
Old Mar 31, 2004 | 12:00 PM
spaceman's Avatar
Default Re: b16 vtec (limpy)
i got a b16 in my crx and i dont really feel any vtec engagemnt,maybe its cuz my tps sensor isnt adjusted properly,i dont know what it is supposed to feel like..hopefully someone on this site can help us out some
Old Mar 31, 2004 | 12:11 PM
92b16vx's Avatar
Default Re: (TIRENECK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK &raquo;</TD></TR><TR><TD CLASS="quote">you expect a pull like F&F when they hit nos(muahahah)? u will not feel anything when vtec engages, only hear it.</TD></TR></TABLE>
You ever driven a B16A rex, or a B16A Civic? I doubt it with a retarded comment like that.
Old Mar 31, 2004 | 01:28 PM
doublejz's Avatar
i have a b16 in a eg and it gets loud as hell and it pulls a little more, not like n20 or anything but def. accelerates through rpms quicker
Old Mar 31, 2004 | 01:32 PM
ensracer's Avatar
Default Re: (doublejz)
i got the same problem with my h22 civic... i have done everything and got nothing... i can hear it work but nothing happens.
https://honda-tech.com/zerothread?id=817206
heres the thread if you want to look at the things that i tryied
Old Mar 31, 2004 | 01:35 PM
TIRENECK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote">
You ever driven a B16A rex, or a B16A Civic? I doubt it with a retarded comment like that.</TD></TR></TABLE>
semi built b16 on a rex. Yea, probably a retarded comment but I think that vtec is something that is more noticeable then felt.
Old Mar 31, 2004 | 01:39 PM
limpy's Avatar
thanks for the info, I was just heard that you shold fell a little more pull rather than only hearing it. thanx again
Old Mar 31, 2004 | 01:41 PM
KillerBee's Avatar
Default Re: (limpy)
is you car throwing any CEL codes?
Old Mar 31, 2004 | 02:06 PM
kreush33's Avatar
Default Re: (KillerBee)
I have a b18c in my EG civic and my brother had a b16a in his CRX and in both when vtec kicks in you definatly can feel it pull, if you are just hearing it i would suggest making sure the vtec is actually engaging and you aren't just hearing something else. What RPM is your vtec kicking in at? what ECU are you running?
Old Mar 31, 2004 | 03:25 PM
spaceman's Avatar
Default Re: (kreush33)
does the tps sensor have anything to do with vtec?
Old Mar 31, 2004 | 06:19 PM
SleepyHF's Avatar
Default Re: (spaceman)
not that I know of...maybe oil pressure! if not that take the solenoid off and check to see if the screen is clogged, that happened to me once
little dx that could
Sep 27, 2007 04:25 AM
b16edeg
Sep 21, 2007 11:48 AM
B16Jacques
Aug 24, 2006 01:40 PM
jdmwidebody094
120
Sep 25, 2003 04:50 AM
RFX
Aug 10, 2002 11:03 AM
