hit a curb some input pleaseee
Old Mar 31, 2004 | 10:15 AM
SNsLude's Avatar
Default hit a curb some input pleaseee
last night i hit a curb at around maybe 15 mph (front passenger wheel) and i was fairly adjacent to the curb, so i hope that reduced some damage.
the result:
- when i drive the car, the steering wheel needs to be turned a little bit to the right (id say about a 10/4 o'clock position ) to drive straight. aside from the cosmetic damage to the rim and tire, and the irregular steering position, everything else *seems* to be okay. i dont hear any noises out of the blue (as i read some people have had), and the distance from fender to wheel, on the left and right wheels, are pretty much equal in distance (could possible be off by a half cm, i just quickly checked with a measuring tape, seemed ok though to the naked eye.)
i know either way i have to get an alignment done, but are there ne steps i should take -before- that? the people at the alignment shop should tell me what else is damaged/bent right? whats a good price to get alignment done? im located in San jose, CA, does any1 recommend a shop around my location, if not, the bay area? thanx alot guys
-steven
Modified by SNsLude at 12:11 PM 3/31/2004
Old Mar 31, 2004 | 10:24 AM
NoLipRacen's Avatar
Default Re: hit a curb some input pleaseee (SNsLude)
well i know when i curb checked i was going alot faster and coming in at a hard angle, basically i bent the lca and bent the frame a bit, i replaced the lca but i still need to get a frame pull (what alignment shop said) and then i should be set. and usually the shop wont do an alignment if somethings bent because they usually set everything to factory specs.
Old Mar 31, 2004 | 10:34 AM
SNsLude's Avatar
Default Re: hit a curb some input pleaseee (NoLipRacen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoLipRacen &raquo;</TD></TR><TR><TD CLASS="quote">well i know when i curb checked i was going alot faster and coming in at a hard angle, basically i bent the lca and bent the frame a bit, i replaced the lca but i still need to get a frame pull (what alignment shop said) and then i should be set. and usually the shop wont do an alignment if somethings bent because they usually set everything to factory specs.</TD></TR></TABLE>
i c, so if the shop sees that a tiebar/control arm or anything is damaged, they just wont do an alignment at all? charge free for just looking at it right? thanx for your input
Old Mar 31, 2004 | 10:41 AM
OTT's Avatar
OTT
Step 1. Get a new rim
At 15mph I couldnt see you damaging any more parts than what you have already listed Plus maybe..
*tie-rod Ball joint
*Radius rod (streching rod= bad Caster)
Worse casescenario:
*bent Inner Steering Arm (tie-rod)
*bent Control Arm
or even
*BENT INNER CONROL ARM MOUNT = Replace ment cradle!!!!
(Although the last one would take at least 35mph; believe me I know)
Modified by OTT at 7:51 PM 3/31/2004
Old Mar 31, 2004 | 11:13 AM
SNsLude's Avatar
hey guys, just put up a quick pic on the rim / tire damage indicated by the red arrows, hopefully it gives a little more insight on the damage / problem... rim wasnt damaged too bad... thanx again
Old Mar 31, 2004 | 12:57 PM
Prelude MIke's Avatar
I have belgum blocks and a loooong driveway ive curb checked at all speeds (my pooor rims). But i do have an alignment prob and was told about 65 bucks just for the alignment itself (i live in NJ) As for the rest im not sure on...yet
Old Mar 31, 2004 | 12:59 PM
SNsLude's Avatar
Default Re: hit a curb some input pleaseee (Prelude MIke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude MIke &raquo;</TD></TR><TR><TD CLASS="quote">I have belgum blocks and a loooong driveway ive curb checked at all speeds (my pooor rims). But i do have an alignment prob and was told about 65 bucks just for the alignment itself (i live in NJ) As for the rest im not sure on...yet </TD></TR></TABLE>
cool, thanx for the price, was about to pay more for alignement at this one shop
Old Mar 31, 2004 | 01:19 PM
AndyD's Avatar
If you need another OEM rim, let me know. I have one available.
Type_R_Lover
Jan 20, 2006 01:50 PM
Idiotboy
Nov 23, 2005 07:52 PM
SNsLude
Mar 31, 2004 02:05 PM
VTECRaZeR
Mar 24, 2004 10:45 AM
prendi
Apr 7, 2003 12:12 AM
