Help: How do i use a Top Engine Cleaner????
Old Mar 31, 2004 | 08:08 AM
imaginary17's Avatar
Default Help: How do i use a Top Engine Cleaner????
I just bought a Top Engine Cleaner from Acura.
I'd like to know how to use it.
Old Mar 31, 2004 | 08:13 AM
purplegsr's Avatar
Default Re: Help: How do i use a Top Engine Cleaner???? (imaginary17)
https://honda-tech.com/zerothread?id=806861
I think you do the same thing as with Seafoam, like in this DIY
Old Mar 31, 2004 | 08:55 AM
jdmfours's Avatar
Default Re: Help: How do i use a Top Engine Cleaner???? (purplegsr)
Motor Flush..? Sea Foam..? what's the difference?
Old Apr 1, 2004 | 08:10 AM
Default Re: Help: How do i use a Top Engine Cleaner???? (jdmfours)
This top engine cleaner is a spray.
Old Apr 1, 2004 | 09:22 AM
purplegsr's Avatar
Then you probably want to spray it into your throttle body and bust out an old toothbrush and scrub all the gunk off. Look up instructions for Seafoam DeepCreep, it does the same thing. I think some people use the spray in the same way described in the seafoam DIY, they just spray it into the brake booster line and let the engine bog and smoke, then shut it off and let it sit, then start it up and drive it hard.
RedneckRicer
Paint and Body
May 10, 2008 06:33 AM
Midori Green
17
Apr 27, 2007 02:06 PM
DevinW
Aug 28, 2002 09:02 AM
