radiator fan
Find your fan switch. On my '95 it's in the thermostat housing. Unplug it & jumper the plug with a paperclip or something. That should make the fan run (key on). If that works, your fan relay, fuses, motors, etc. are all OK. If not, then put 12v on the fan motor itself to see if it runs. Then you have to check the fuse & relay...
The best way to check your fan switch is to put it in a pot of hot water along with a thermometer. Use an ohm-meter or continuity tester, the switch should close at whatever temperature it's marked (90C/194F??)
If you want you can splice a switch into that wiring harness, but leave it plugged into the fan switch. You can turn on the fan whenever you want, but if you forget, the factory fan switch is still there.
Yea my friend had it in his 92 hatch but the thing is, there is no wires plugging into my water pump(atleast i think thats where your talkin about) its a 91 B16 in an 88 teg and i did the swap myslef but i dont see any wires plugged into the water pump and i dont even care if i have a switch if i could just get it to run all the time then that would be cool to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16TeG88LS »</TD></TR><TR><TD CLASS="quote">Yeah well atleast my valve cover isnt Orange you *****</TD></TR></TABLE>
FORD RED *******..... and at least mine isn't Goof Off'd you ****!
this is a discussion about radiator fans.... now back to the subject, i have the switch in my center console but it isn't hooked up. i would like to have it run sonstantly too.
well i am actually getting a new radiator, and i wish i had a switch on my console that was hooked up to nothing also lol, and i wish i had to push my sun roof up everytime i wanted it open to haha
thisdamnhonda
21
Feb 26, 2012 09:47 AM
