how to fix synchro?
Old Mar 31, 2004 | 05:40 AM
Ichigo's Avatar
Default how to fix synchro?
How do you fix a synchro on a 93 prelude vtec???
Old Mar 31, 2004 | 07:11 AM
NoLipRacen's Avatar
Default Re: how to fix synchro? (R34lude)
are you asking the actual process with the tranny out and disassembled? or are you wanting to know the entire thing and how easy/hard it is?
basically you need to drop the tranny, then separate the 2 housings and replace the pieces
Old Mar 31, 2004 | 11:26 AM
jc836's Avatar
You replace it. There are no repairs for a failed synchro. You can try a temporary fix using GM/Pennzoil Synchromesh fluid-but that will be a band-aid.
Old Mar 31, 2004 | 11:40 AM
'99luder's Avatar
Default Re: how to fix synchro? (jc836)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc836 &raquo;</TD></TR><TR><TD CLASS="quote">You replace it. There are no repairs for a failed synchro. You can try a temporary fix using GM/Pennzoil Synchromesh fluid-but that will be a band-aid.</TD></TR></TABLE>
How long is temporary with Sychromesh?
Old Mar 31, 2004 | 12:06 PM
KENLUDE97's Avatar
Default Re: how to fix synchro? (prelude97)
Depends on how long it was being drove on with the bad Syncro.... Just a little wile you can add the GM Syncromesh and it will feel like new... But if it has been drove on for a wile... Then it is a toss up... Can not hurt to try.. 2 Bottles are $20.
EF9ZC
14
Apr 1, 2006 08:57 AM
chinaxiong
Aug 9, 2005 11:13 AM
dadado
May 19, 2005 09:12 AM
jerbear!
Mar 16, 2004 09:47 AM
Integra_WA
Aug 18, 2003 07:47 PM
