Intake instalation for 90 lx
Ok i have a long ram intake running off the old rubber **** from where the old air box used to be. Ive seen some peoples with like a hole running into the wheel well. by the look of it it seems like if i cut a hole the intake will be between the wheel and the fire wall. Please help, what can i do. Now i have the intake going to the front right behind the radiator fan! HELP
if it consumes any water into the engine wont the engine start to putter and bogg out? Right now the filter is right under the fan to the radiator and 4 inches from the bottom of the bumper. If i cut the hole and run the intake into the wheel well (between tire and fire wall) will it be ok there? Again what about water getting sucked into the engine, friend had it happen to him and the motor was done for.
1 more thing ever since i put the intake on the clutch has seemed to be getting stiff at times. somtimes its soft and sometimes its stiff as ****.
Hydrostatic seizure is some bad stuff man. I don't know what to tell you man. did you look to see if you can see where the stock airfilter had it's air coming from? There should be like some black tubing. Most cars you remove that and then place the filter in there.
april fool's about my water post..
you will have to enlarge the hole below the battery so the filter fits inbetween the fender and lining.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SearchBeforeUPost! »</TD></TR><TR><TD CLASS="quote">april fool's about my water post..
you will have to enlarge the hole below the battery so the filter fits inbetween the fender and lining.</TD></TR></TABLE>
No! ..... really?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John Gordon »</TD></TR><TR><TD CLASS="quote">
No! ..... really?</TD></TR></TABLE>
well I thought I would make it crystal clear for these folks:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord_Speed »</TD></TR><TR><TD CLASS="quote">if it consumes any water into the engine wont the engine start to putter and bogg out? Again what about water getting sucked into the engine, friend had it happen to him and the motor was done for. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Obsidian »</TD></TR><TR><TD CLASS="quote">Hydrostatic seizure is some bad stuff man. I don't know what to tell you man. did you look to see if you can see where the stock airfilter had it's air coming from? There should be like some black tubing. Most cars you remove that and then place the filter in there.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0nda Acc0rd »</TD></TR><TR><TD CLASS="quote">If it gets water you will prob get hydrolock </TD></TR></TABLE>
MAX PAYNE
15
Aug 16, 2006 06:26 PM
soulrider4ever
Mar 8, 2004 05:21 AM
Speed_Ricer99
Feb 15, 2002 08:58 AM
