phillips hella ballast question
Old Mar 31, 2004 | 01:36 AM
typeRSXS's Avatar
Default phillips hella ballast question
i was wondering, the ballasts that are used in the plug/play kit, say for 9006, would it be possible to use the same ballasts for d2s/d2r? if so, is it direct plug or do i need to do something? thanks
Old Mar 31, 2004 | 03:28 AM
ebelp's Avatar
Default Re: phillips hella ballast question (shupaGSR)
Not real sure what you're asking, but...Philips ballasts will work with either d2s or d2r capsules. The same goes for Hella. The capsules have a "universal" socket at their base.
Old Mar 31, 2004 | 03:43 AM
96 Ls lnTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shupaGSR &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering, the ballasts that are used in the plug/play kit, say for 9006, would it be possible to use the same ballasts for d2s/d2r? if so, is it direct plug or do i need to do something? thanks </TD></TR></TABLE>
YES you can use the same ballast, but you have to get the connector need from Alex @ Xenon Factory (they are $20 a Pair) you actually have to, cut an solder
Old Mar 31, 2004 | 05:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If they are like my visualdynamics kit, which used 9006 rings glued onto the bulbs and retained the OEM D2 connector, then yes you can use the same ballasts no problem. I got new D2S bulbs to go in my HID retrofit and I just kept the same ballasts.
Old Mar 31, 2004 | 01:27 PM
Default Re: phillips hella ballast question (PatrickGSR94)
if you already have hid ballast with 9006 connectors email alex for these
USDM-EK4*
Apr 20, 2007 06:01 PM
jdmcivicb16a2sc61
13
Dec 3, 2006 12:22 AM
01blackgsr
Jan 18, 2006 08:12 PM
MugenHonda
Dec 10, 2004 09:07 AM
slowacura
Nov 22, 2003 10:11 AM
