Coolant overflow bottle question????
Old Mar 30, 2004 | 09:16 PM
96 Ls lnTeG's Avatar
Default Coolant overflow bottle question????
Well I posted this in the Integra forum got no real answers so hope could help me out
I am thinking about relocating my Overflow does it have to be level with the radiator???
Old Mar 31, 2004 | 04:31 AM
JimBlake's Avatar
Default Re: Coolant overflow bottle question???? (96 Ls lnTeG)
It would work better if it were up higher. But it would look kinda funny being up above the hood...
If you mount it lower, the radiator would need a little more suction to draw coolant back in when it cools down. If you put it far away, then you just need a longer hose, but you'd have to bleed air out of that hose, which would be a pain. Either way, it's not impossible. But any 'vacuum leak' in that hose lets the radiator suck air instead of coolant when it cools down.
Old Mar 31, 2004 | 04:44 AM
Default Re: Coolant overflow bottle question???? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">It would work better if it were up higher. But it would look kinda funny being up above the hood...
would it matter if I have a radiator with 20psi cap would I get more suction out of that?
Old Mar 31, 2004 | 04:55 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 Ls lnTeG &raquo;</TD></TR><TR><TD CLASS="quote">would it matter if I have a radiator with 20psi cap would I get more suction out of that?</TD></TR></TABLE>NO. That's the pressure when it opens (hot) to push coolant out to the bottle.
When it cools down, the cap opens a different vent, which opens really easy, to suck coolant back in. But the amount of suction isn't controlled by the cap. If you put the reservoir down too low, maybe a radiator hose would collapse first, before sucking coolant back in. I'm not even sure if this would happen.
Try it & see, but for now, don't do anything 'permanent'. If it's not good, then you can put it back to stock.
thebarless
Oct 19, 2006 01:03 PM
RockLee`
16
Sep 28, 2005 03:15 PM
fanta!
Aug 14, 2005 02:14 PM
e jay one
20
May 19, 2005 08:37 PM
betsuni
Oct 25, 2001 08:47 AM
