My New Mod..(1pic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">I hate to say it, but the Cusco cage is really more of a show cage than anything. </TD></TR></TABLE>
blah blah..
The guy I got it from has been running it for a couple years now, one of his cars flipped and totalled.. the cage is mint! He is running it in his other Hype-R now..
People get into big disputes about these cages, but yet everybody is using them on Circuit, everyone who can afford to use it for lapping does. But the real racers use full weld in cages. I still drve my car to school and I just wanted to be a bit safer on the track, plus It couldnt hurt payhing less then half of the actual cost of the cage..
And the bars arent as thing as they look, they are solid. The smallest of the bunch weights a lot! And bleive me, after seeing tuns of crash pictures of owners whove had the cage, I wouldnt say safety is not an issue, because the bars held up!
blah blah..
Oh and its 2.25 inches thick, I just measured it. I will try and get it in tomrrow, my friend with his SC400 and another with his TT300ZX want to get some pics, so I think well get a group shot and some cage shots..
18 holes I need to make, with this cage its manderally bent (cant spell) so that it doesnt have to go through any vents, and I can dislocate the side bars and make it 4 point on the street, add 2 botls then Im 6 point on the track. I put it togather in my living room in 5 mins max, the hard thing is going to be drilling the holes with out hitting anything..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Hate Cones »</TD></TR><TR><TD CLASS="quote">Oh and its 2.25 inches thick, I just measured it. I will try and get it in tomrrow, my friend with his SC400 and another with his TT300ZX want to get some pics, so I think well get a group shot and some cage shots.. </TD></TR></TABLE>
Circumference or diameter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dased530 »</TD></TR><TR><TD CLASS="quote">how would something like this do on a head on collision ?</TD></TR></TABLE>
In all honesty, I dont think very many cages can do much for you. I still have my air bags, I still have my harnesse's, and the cage is going to be keeping the front from crushing in (if I use all 6pt of it)..
I have only see picturs of roll overs, and side swipes..
Im not quite sure.
Im not quite sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastSS »</TD></TR><TR><TD CLASS="quote">for driver safety?
probably nothing at all
however if it were a weld in cage, with a good racing seat, and 4points, helmet and hans device... it would probably help bigtime</TD></TR></TABLE>
OMP seat
Hans Device
Approved Helmit
Fire Suit..
Other then welding it in, I guess you could say im failry safe..
but aside from welding, its just as strong, as pics have proven its duribility..
and as far as being safe on a head on collision.. its pretty much the same as any other cage, autopower.. weld, etc. Unless you construct some sort of front re-bar, then its going to do the same any other bar does, if not better...
Modified by I Hate Cones at 1:48 PM 3/31/2004
OMP seat
Hans Device
Approved Helmit
Fire Suit..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE »</TD></TR><TR><TD CLASS="quote">how does that install? pull the hatch and interior and bolt it on? you cant use rear seats with this right? what holes does it mount to? this is for a dc teg right? thanks</TD></TR></TABLE>
It has 18 bolts, which you need to predrill in your floor..
rear seats must be taken out..
its for 94+ dc chassis..
OMP seat
Hans Device
Approved Helmit
Fire Suit..
and as far as being safe on a head on collision.. its pretty much the same as any other cage, autopower.. weld, etc. Unless you construct some sort of front re-bar, then its going to do the same any other bar does, if not better... </TD></TR></TABLE>
Thats all good and dandy on the track, but he said this is a daily driver, if you get in a wreck your gonna get hurt pretty bad since the bar is like 2 inches from your head, since no one wears helmets daily driving, unless if your sick ****. Hence, why many state the Cusco rollcage as "show" piece.
Also padding it doesnt help much when your head hits it without a helmet, and you seem to forgot some padding on the passenger side?
OMP seat
Hans Device
Approved Helmit
Fire Suit..
Im not quite sure. </TD></TR></TABLE>
No what the cage is mainly going to do is keep your neck from snapping if you roll over while strapped into those harnesses.
Harness + rollover protection
